Rear end identification
Old Apr 7, 2011 | 06:48 AM
1987notchback's Avatar
1987notchback
Default Rear end identification
so i cannot find my build sheet for my truck. is there another way to tell what rearend i have? could i somehow check the numbers on the rearend? thanks mike
Old Apr 7, 2011 | 06:57 AM
abarmby's Avatar
abarmby
You have a 1500 which means you have a 9.25 rear end.
If your talking about what ratio you have in the rear and if you have an lsd, then you will need to send your Vin number to Dodge and they will pull your build sheet for you.
I believe you can do this on-line on the Dodge web site.
Someone will chime in.
That or, pull your pumpkin cover and look for the LSD and clutchpack etc inside. Plus counting the revolutions of your drive shaft per number of times your rear wheels tur.
Hope this helps?
Al.
Old Apr 7, 2011 | 08:36 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Agreed, you can email Chrysler or stop by a dealership and see if they can bring it up for you.
Old Apr 8, 2011 | 05:02 AM
1987notchback
cool thanks guys
Old Apr 8, 2011 | 04:55 PM
HemiLonestar's Avatar
HemiLonestar
See if your sticker is still inside the glovebox.
Old Apr 9, 2011 | 04:56 AM
1987notchback
i checked it is not there
