06 Hemi Misfire
06 Hemi Misfire
I've been trying to troubleshoot this issue with my 2006 Dodge Ram 1500 5.7L Hemi for about a month now. I keep getting the code P0306 (cylinder #6 misfire).
Here's what I've done so far:
-Replaced all plugs
-New Coil Pack on #6 (I moved the new coil to multiple cylinders to make sure I didn't get a bad one)
-Swapped injectors
-Ran Compression Test - compression is good
I took it to the local Dodge dealer and they found code P2317 Ignition Coil Secondary Circuit.
Any ideas???
Any help/suggestions would be appreciated
-Replaced all plugs
-Swapped injectors
Any ideas???
