Cold air intakes & exhaust
Old May 15, 2011 | 10:37 PM
  #21
HEMI1980's Avatar
HEMI1980
Thanks for the fast response. I am looking at these below.
http://www.amazon.com/Flowmaster-817...2005&carId=001
http://www.streetsideauto.com/p/flow...thunder-17397/
I am just not sure which one.
P.S. If you have any points on a good CAI I would aappreciate that as well. lol
Old May 15, 2011 | 11:04 PM
  #22
truegent81's Avatar
truegent81
you joined DF to obtain info about your truck. and i am in the same situation as you...soooo many choices about CAI. however, hammer has given soo much info. and out of all the info, i am going with the home depot CAI. that is what hammer seems to be saying is the best as well. ALSO, by joining this forum, it kinda goes hand in hand with being able to eventually DIY.
and say you do want to spend $300 on a CAI..great, fine, but if your not doing any more mods to the engine or exhaust off the bat, just do the home depot one until then. $60 while saving up to di the other mods seems reasonable. i plan on doing my CAI during memorial weekend. hopefully by the end of the year new headers and exhaust. BUT, during the next 6 months i can save up and read up on the other mods. once these mods are complete, i should in theory have enough saveed up for a CAI. if my home depot one works just fine with these other mods, i just saved up an extra $300 or so to put towards other fun toys...think of it this way...thats my two cents
Old May 16, 2011 | 08:47 PM
  #23
lxman1's Avatar
lxman1
Site Moderator
Look up a magnaflow kit. Much better flow and quality.
I got mine here for just over $400 shipped to my door. All stainless and fit's very nice.
The Flowmaster muffler flows no more than your stock set-up.
http://www.performancepeddler.com/de...CT_ID=MAG15863 offer $400 and see what they counter offer.
Old May 17, 2011 | 11:21 AM
  #24
weedahoe's Avatar
weedahoe
Hall of Fame Member
Check out this link also
https://dodgeforum.com/forum/parts-s...ir-intake.html
Old May 17, 2011 | 02:48 PM
  #25
truckin151's Avatar
truckin151
Personally, when I swapped out from my old aFe kit and dropped some cash on my new vararam I can honestly say it has made a difference via ET's and 0-60 times. I picked up 2 tenths in my 0-60 and 4 tenths in my 1/4 over the old setup. Then again I also do not believe that just an intake will give you the results I got even if its the same intake since I have done so much to get it running strong. CAI are a supporting mod, not a "main event" mod so hge gains just wont happen wih them alone.
Exhaust, just stay clear of flowmasters and you'll be good. They dont flow very well and you sacrifice performance for a few extra decibles. Also, unless you like the chrome tips sticking out the side/back of your truck, there is NO reason, let me re-emphisize that, THERE IS NO REASON to spend the extra $$$ on a catback. All a cat back is, is a little better piping material, muffler and is basically for looks, 0 performance gain off it as they do not replace the restrictive Y pipe. Buy a good muffler that has the sound and performance you are after, pick up aq magnaflow Y pipe and dont worry about anything else (unless spending $400-$800 on a catback is what you want to do).
Old May 17, 2011 | 03:00 PM
  #26
HEMI1980's Avatar
HEMI1980
IXMAN1:
Thanks for that link I did check it out. Thats pretty cool.
TRUCKING151:
So there is no point to buying a cat back ? Please xplain the difference between buying one, and not buying one ?. Whats the disadvantage/advantage ?
Thanks,
Old May 17, 2011 | 03:06 PM
  #27
HEMI1980's Avatar
HEMI1980
For a CAI, I was looking at this model. And I have been reading from peoples opinions and fifferent models non stop. And I have concluded this is a great model for a 05 ram hemi 1500. http://www.amazon.com/57-1533-Fuel-I...5659063&sr=1-7
Any opinions as well ? And I am condisering diy technique as well still.
Old May 17, 2011 | 03:09 PM
  #28
truckin151's Avatar
truckin151
Your truck already has 3" tubing from the factory, which is a good size, it just has a crudy Y pipe connection and a restrictive muffler. When you buy a catback, it only replaces up to that crappy Y pipe forward, it gives you some better tubing material gets you a new muffler and then lets the pipe exit where ever you want it for looks. Most of the time, the muffler will cost $50-$150 but the catback will cost $400-$800. You can take your truck down to any exhaust shop, have them remove the stock muffler, stock resonator, and cut out the stock Y and add in the new stuff for a fraction of the cost. The end result is you have the same sounding/performing system, minus the look and you save $200+ depending on the setup. If a pipe does rust out, you can buy a new one and have it welded in for cheaper still.
So unless you want the look of a catback, there is no point to them. One good point, however, is with a catback, most of the kits you can put together in your driveway as they are "bolton/clamp on" ready. So you can save some cost on the install there.
Old May 17, 2011 | 03:21 PM
  #29
HEMI1980's Avatar
HEMI1980
It would be nice to have the dual side exit ones which I find so appealing. However its to bad you can combine the tubing with a different exhaust like a cherrybomb glasspack. I think that would sound sick.
Old May 17, 2011 | 03:22 PM
  #30
HEMI1980's Avatar
HEMI1980
TRUCK151 where did you get your headers, and camshaft ?
