Y pipe recommendations
Got mine from Summit too. They typically arrive to my area the next day from their NV location. 2-3 days if coming from OH which was the case for my muffler.
I have a aftermarket Y already and it even looks restricted compared to the Magnaflow Y. Can't wait to have both installed.
Dynomax Ultra Flo Welded Muffler
Nice, yeah I am in the same boat. I can't wait to get my new Y on and delete the final resonator. I didn't do it originally because I was not planning on getting a tuner to disable the MDS. Oh how things change... I don't know what year your truck is (judging by your key, I would say pre-06) but does anyone have any info on deleting the resonators? Should I delete them both?
Sil, thanks for the clarification.
bgbluram2
here is a shot of my Y pipe installed. it is not that great of a shot to show you how it ties into the rest of the system, but it was installed in the front resonator location, which was directly behind the stock Y. you will have to bend and weld in some additional pipe to tie into the stock down pipes after the cats.
i will see if I have any better pictures on my computer at home
nateroach
EDIT
here are a couple more pictures that I found. It's the best that I have handy, but still no shots showing the whole setup.
that down pipe is covered in trans fluid as I just did a pan drop and installed the mag-hytec pan.
bgbluram2
nateroach
EDIT
Thanks for the pictures. Yeah I got under there and was wondering where they would fit the new Magnaflow Y-pipe where the stock one is, but after seeing yours I see that they pushed it back behind the cross member and then just ran additional piping. That seems like the best and easiest way to do it.
Why is there new piping going up towards the manifold on the drivers side?
