rebuild, or buy 4.7L, or 5.9L
I am in a rock and a hard spot guys.. I have a ram 1500 and it has a hole in the main something on the bottom of the block. I have been told that I should just buy a whole new motor because this part is bored to the specs. of the block and that just getting a new one is impossible.. I have no clue. I need help.
I blew a hole in a 4.7.. I can't find one to replace it for less than $3000. So I am trying to figure out whether it would be better just to get a new one, rebuild my old one, or put a 5.9 in it.. I have found alot more 5.9's for $1200 and even cheaper.. But I have heard that there is alot that I would have to do to convert..
Trending Topics
Yup. You would basically need a whole donor truck. Transmission was different, wiring, many sensors, PCM, etc. etc.
The tranny behind the 5.9L V8 was a 46RE. The 545RE behind the 4.7L V8 and Hemi is a lot more reliable. Take a peak into the 2nd gen section and look at all the threads about the transmission. It you treat it right, it'll usually be fine, but you abuse it even once, and it can bite you in the rear (total rebuild). If you go the 5.9L route, rather than pay money for an iffy stock 46RE, get one from these guys. They build up the 46REs to be very durable and very reliable.
Reliable is all I care.. New or rebuilt is no different to me. I can do all the work myself, and I have always wanted to do it.. I might be on here for tips once I can make my mind up on what to do here.. It looks like it is going to be cheaper to go with the 4.7. Now maybe someone on here knows a reliable source to get one from with a decent warranty on it..
