NEW Here.. Lifting help
Old Aug 1, 2011 | 08:55 PM
shrimp_2's Avatar
shrimp_2
Default NEW Here.. Lifting help
I recently bought an 06 1500 2wd and want to do like a 2-3'' lift to fit 35" tires. My problem is that I'm having trouble finding a lift. Will 4wd spindles fit on a 2wd? Pictures would be appreciate too. Thanks!
Old Aug 1, 2011 | 09:48 PM
08HEMI1500's Avatar
08HEMI1500
airbagit.com has 3" spindles for the 2wds. If thats all you want then go with those.
Old Aug 2, 2011 | 01:16 AM
Brandon Anderson's Avatar
Brandon Anderson
Welcome to the site.
Your best bet is the 3" chassistech spindles, as mentioned above. $270 shipped from ebay, you and a friend could install them in around 4hrs with the right tools. If you do nothing to the rear, the 3" spindle is basically dead-on level after an alignment.
Old Aug 2, 2011 | 08:10 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Also check out www.cstperformance.com
Old Aug 3, 2011 | 08:40 PM
shrimp_2's Avatar
shrimp_2
thanks weed. I'm going to go with the CST 4' spindle lift and possibly a block in the rear and run 35s. should i get new shocks and if so what kind that's not too expensive. thanks
Old Aug 3, 2011 | 11:47 PM
08HEMI1500's Avatar
08HEMI1500
The CST kit comes with shocks
Old Aug 4, 2011 | 03:27 AM
Matt99's Avatar
Matt99
you dont have to get new shocks but if I were you, I would get the monroe coilovers for the rear. They will raise it about 1.25-1.5in which would not only make it level, but also make towing a little easier on the handling/stance
Old Aug 6, 2011 | 05:57 PM
shrimp_2's Avatar
shrimp_2
did the chassistech sway bar issue ever get fixed? they're a lot cheaper than the CST spindles which do not include shocks. 4 wheel parts says i need longer shocks, and should get a 1" block and rear u bolts.. is this true? they're total price for everything including rims and tires is $3700. too much for me!
Old Aug 6, 2011 | 06:07 PM
HammerZ71's Avatar
HammerZ71
4 Wheel Parts is like going to a dealership to buy a vehicle. They start out at retail and stupid, crazy high labor prices but will deal if you push them.
They quoted me $2500 for my gears, master install kit, installation and an Auburn LSD which I laughed at. It took 3 trips there and a few printouts of prices I found online for the parts, but they ended up coming all the way down to $1700 + tax for the job. That's $800 someone who didn't know any better would have over-paid for the job. As a result, even though I got a good deal in the end, I don't buy from them unless I need something pretty bad and can just drive the 30 minutes and get it.
$3700 is crazy high, but might be you wanted some big, honkin' expensive wheels too. Without knowing exactly what you quoted, we can't say how out of line they were.
You know you can always look into a 3" PA body lift kit for about $350 and install it yourself. Not a hard job. A weekend thing with basic tools, a jack, jack stands and a helper would be nice. You want a little more height and it to sit level? Then add a $100 set of coil spacers up front. That'll give you roughly 5" and will look nice with 35s...
Old Aug 6, 2011 | 06:19 PM
shrimp_2's Avatar
shrimp_2
the $3700 included: CST 4" spindle lift, 1" block kit, rear u bolt, brake lines, 4 ES9000 shock absorbers, 4 MHT Fuel 17x9 wheels, BFG 35" tires, and installation
