air filter... how big is too big?
Old Aug 8, 2011 | 07:00 PM
SLT8's Avatar
SLT8
Default air filter... how big is too big?
Just like an exhaust pipe sizing, is there a certain baseline or limit to how big of an air filter you should have? My new one is a freaking monster @ almost 2lbs and 11" tall. I am not to sure if this is too much or if the only limit is per your bay fitment space.
Thanks.
Old Aug 8, 2011 | 08:07 PM
chambers's Avatar
chambers
The size/surface area of the filter isn't relevant, the piping can be too big just like for exhaust. Since the cold air intakes use a 4" tube for the hemi, as long as your tube and filter inlet is that big you should be good. Donaldson/volant power core filters have huge surface areas since they are essentially a big roll of filter element and don't adversely effect performance. What filter is it, got a link?
Old Aug 8, 2011 | 10:42 PM
SLT8's Avatar
SLT8
That makes sense regarding the piping.
Filter is K&N 1026.
http://www.summitracing.com/parts/KNN-RF-1026/
11" Media Height
6" Inlet Flange
7" top OD
7.5" bottom OD
Old Aug 8, 2011 | 10:55 PM
Marklorenzo's Avatar
Marklorenzo
6" inlet flange, that would mean the piping is six inches?
Old Aug 8, 2011 | 11:01 PM
SLT8's Avatar
SLT8
Its a BFI that i got cheap on eBay. The end tube diameter is 6"
Old Aug 9, 2011 | 12:06 AM
lxman1's Avatar
lxman1
Site Moderator
It funnels from 6 to 4". They put the open filter down real low and are is danger of sucking up water. Not the best design for a daily driver, but ok for a weekend warrior.
Old Aug 9, 2011 | 09:11 AM
SLT8's Avatar
SLT8
The new filter is sitting right up to the grille so i may have to do some adjusting so it in further to avoid sucking up rain like you said.
Old Aug 9, 2011 | 11:37 AM
John  M's Avatar
John M
The size / filter area absolutely does make a difference. You can't be "too big" (insert chuckle here) but the more area you have, the less restrictive it is. They can use a more effective media and offset its lower performance by using more of it. That way you get good filtration and good flow too.
Old Aug 9, 2011 | 12:22 PM
bgbluram2's Avatar
bgbluram2
Kay, I don't think you will have any problem with that filter placement unless in a really bad rainstorm. A lot of those filters actually drop down in front of one of the tires which is a bad place as water can get splashed up from the road and get sucked into your intake.
Old Aug 9, 2011 | 02:12 PM
lxman1's Avatar
lxman1
Site Moderator
Yep, since you have the front mounted TB, you're not hanging down as low as it would on the std Ram intake.
