Spray in bedliner
Old Sep 2, 2011 | 12:15 AM
Chris_03_Hemi_4X4's Avatar
Chris_03_Hemi_4X4
Default Spray in bedliner
I'm going to attempt a spray in bedliner next weekend, anybody in the Dallas area done this before that can possibly lend a hand? just let me know. I have never done one before and could use all the help I can get. Going to use an Al's Kit but planning on tinting it to match the truck and still trying to decide if I will do it over the rails or not. Anybody have any input on that?
Chris
Old Sep 2, 2011 | 12:40 AM
Caseys-dodge's Avatar
Caseys-dodge
I don't know anyone personally that spray the bed themselves, when I had my silverado I had a Rhino Liner sprayed in and over the rails and I loved it. When I got the Ram it already had a spray in liner but only in the bed and the first thing I bought were the black diamond plate bed rail caps (which don't fit as good as I wanted). If you are going to spray it yourself and can tape a very straight line I would say go up and over the rails. It's definitely worth it for the extra protection and it looks good.
Old Sep 2, 2011 | 01:22 AM
Brandon Anderson's Avatar
Brandon Anderson
+1 on over the rails. That's what's on mine, and it's saved the truck from quite a few dings and scratches.
I'd also recommend going with a high-pressure system like line-X instead of low-pressure. Looks better IMO and I hear they last longer too.
Old Sep 2, 2011 | 10:23 AM
T-Muns's Avatar
T-Muns
Never heard of Al's but after looking it up, it looks decent. I bought a Monstaliner kit and will be spraying it soon. I'm going to use a schutz gun.
Let us know what you go with and how it works out
Old Sep 2, 2011 | 11:21 AM
Chris_03_Hemi_4X4
I pulled the plastic POS drop in out this morning and it made the choice for me. Rubbed everywhere through the paint. I am gonna have to go over the rails, now I am just debating whether to mask off the truck or pull the bed off and do it that way, I think I may end up doing the rocker panels as well to repair some rust spots. idiot previous owner never washed the truck to get all the salt off. I found some under the bedliner this morning.
Chris
Old Sep 2, 2011 | 10:34 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
a buddy and i here locally are going halfs on a spray on setup here soon. maybe you should see about it also
Old Sep 3, 2011 | 07:25 AM
xjfever's Avatar
xjfever
Be sure to take lots of pictures during the process. I plan to do mine with the U-pol raptor liner which can also be tinted to match the paint. I will just use the black though.
Old Sep 3, 2011 | 01:34 PM
Chris_03_Hemi_4X4
After seeing t-muns post I checked into the monstaliner kit and I'm gonna go with it instead of the als kit. Looks to be a better deal. Going to do regular black and doing the rocker panels and back bumper as well as 3 coats on the bed. Was told the 2 gallon kit would be more than enough.
Chris
Old Sep 3, 2011 | 10:32 PM
T-Muns's Avatar
T-Muns
Right on, I think that stuff looks pretty awesome compared to some others. If you can get a little help, taking the bed off is pretty easy. I just took mine off because I chassis saver'd the entire frame, hitch, bottom of the bed, etc to fully clean up and prevent the rust. I also had to do a new muffler and shocks too so having the bed off was easier. Otherwise, just have to tape and cover everything up.
Edit: I forgot to mention I actually broke 2 rusty bolts in the process and had to torch them out of the bed. Buddy has O2/Acetylene so it wasn't too bad.
You'll probably get to yours before I get mine so I'd love to see how it works out for you. They really stress on the prep work to make it work well. A lot of jeep guys are using this stuff so you might want to check out the jeep and 4x4 forums.
Old Sep 4, 2011 | 12:14 PM
Chris_03_Hemi_4X4
Prep work isn't a problem for me. The wife does autobody (I think I'm gonna put her to work since I paid for her schooling). I'm gonna order it next weekend but most likely won't get to it untill fall. When the temp down here cools of a bit.
Chris
