Whats the difference between the TOW button and O/D OFF button?
Old Sep 12, 2011 | 01:41 AM
vikingdiesel's Avatar
vikingdiesel
Default Whats the difference between the TOW button and O/D OFF button?
I obviously know that the O/F OFF means, the truck wont shift into 5th gear (O/D) but what does the TOW button do?
Old Sep 12, 2011 | 07:08 AM
Cthulhu's Avatar
Cthulhu
Tow changes your up/down shift points for better trailer handling, OD Off takes those shift pts and lopps off the highest gear.
Old Sep 12, 2011 | 09:19 PM
ricer's Avatar
ricer
Maybe a stupid question, but here goes. Is it ok to drive in the tow haul mode while just driving around in the city? I hate how my truck is always shifting while going from stop light to stop light.
Old Sep 12, 2011 | 09:23 PM
davb673's Avatar
davb673
I am no expert, but that should not be a problem ricer.
Old Sep 12, 2011 | 09:52 PM
Cthulhu's Avatar
Cthulhu
I do not believe it is an issue. I do it for the same reason. 40kmph is my truck's skitzo area... other than that, its pretty good.
Old Sep 13, 2011 | 09:13 AM
nateroach's Avatar
nateroach
At least on the 06+ 3rd gens tow locks out 5th and O/D off locks out 4th and 5th. they also raise the shift points.
nateroach
Old Sep 13, 2011 | 10:05 AM
Cthulhu's Avatar
Cthulhu
Are you sure that's not just a 1500 thing? I'm almost certain I get 5th gear in T/H mode when I'm towing on my truck, and at least 4th with OD off. My CTD would be reved through the roof if it couldn't get into those gears.
Old Sep 13, 2011 | 10:51 AM
John  M's Avatar
John M
It's been called the "tow / haul ***" mode on other trucks for years
Old Sep 13, 2011 | 01:00 PM
nateroach's Avatar
nateroach
3500's run a different trans (68RFE) than the 1500's (45RFE) that might have something to do with it, but I am pretty sure O/D of is 4-5 lock out.
the 45RFE is essentially a 3 speed wide ratio trans with 2 O/D's slapped on the end (this is why for dyno pulls 1500's go in 3rd gear 1:1 ratio). Hence O/D off disabling the last 2 gears
nateroach
Old Sep 14, 2011 | 09:26 PM
lxman1's Avatar
lxman1
Site Moderator
The 1500 3rd gen uses a 545rfe.
Tow/Haul locks out 5th gear as well as delaying the 2-3 and 3-4 shifts to a higher rpm to keep the engine in a better powerband.
OD off locks out 4th and 5th gears.
