cold air intake and performance chip....
I am thinking of getting a CAI and im just curious what is the beat brand for the money I want to spend ... I wanna spend know more than 250$...
Also what is a good performance chip that is reasonably priced or cheap as I should say and is a performance chip even worth buying?
Make one, you'll spend about $20 in materials plus the cost of your filter choice (anywhere from about $15-35).
Unless you drop big bucks on a TRUE CAI (like the Vararam) any difference between a home-made, fleabay or a brand name one will be minimal and only be told on a dyno. Although some of the fleabay ones are of dubious quality and tend to fall apart.
Use the $ you save by making your own and put it towards a GOOD programmer like a Superchips or Diablo...
here ya go
https://dodgeforum.com/forum/3rd-gen...-included.html
hit weed up i know at one time he had some sweet ones made up that were plastic welded minus the filter
this looks pretty good and i think that i could do that ... but my only concern would be how to fit the sensors in the pipe... i wouldnt know how to do that without messing it up probably
The sensors are easy. I just drilled a hole in the pvc and put a rubber grommet in the hole and shoved the air intake temp. sensor in the grommet and siliconed around it to make sure it had a good seal. You can get the grommets at any auto parts store. I have about $50.00 in mine including the K&N drop-in filter.
Trending Topics
Yeah, I get a six pack of the grommets at Home Depot for like $1.99, they have a groove in them so they snap right into the hole, but I hit 'em with the PVC glue since I have it out to connect the elbows to the straight PVC anyway, but silicone will work too. Just don't plug the sensor in until the glue is dry, you foul a sensor and it's to the auto parts store for a new one...
It wouldn't put out any more emissions than a store bought one, but I believe in CA. it wouldn't pass, I am almost sure anything you add there has got to have a CARB certification stamp...
