Need help with Fogs
Old Oct 27, 2011 | 01:55 PM
SpecialEdJon's Avatar
SpecialEdJon
Default Need help with Fogs
I was looking in my fuse box and seen that it has a relay and a fuse for fog lights. Now im woundering if its alrdy prewired for some and if so where would the wiring be at.
Old Oct 27, 2011 | 01:56 PM
HammerZ71's Avatar
HammerZ71
Should be a wiring harness behind one of the fog light holes. Now the fun part is after you install them and hook everything up, they probably still won't work. You'll have to visit a dealer with the Chrysler StarScan Tool who must then "enable" them in the PCM. Fun, Fun...
Old Oct 27, 2011 | 02:06 PM
SpecialEdJon
only wire i found was one the looked like it had a air senser on it and with i unpluged it the check engine light came on
Old Oct 27, 2011 | 02:12 PM
HammerZ71's Avatar
HammerZ71
There is one behind the bumper that is a sensor for the outside air temp, could be you stumbled onto that. I've not seen one yet that didn't have the wiring harness, but I haven't been into/under a 6 cyl., RC 4x2 either. Might be the more base type models don't have the harness, wouldn't surprise me.
It'd be interesting to know if you have the cab light harness in the passenger pillar too, for informational purposes...
Old Oct 27, 2011 | 02:15 PM
HammerZ71's Avatar
HammerZ71
If you find you need the harness, they are all over ebay for about a third of what the dealers get.
Example:
http://www.ebay.com/itm/Dodge-Ram-Fo...282436&vxp=mtr
But if'n it was me, I'd just get me a set of lights that fit in the hole and wire them up with a separate switch, unless you really want the all inclusive factory light switch. But you'll spend a mint between the harness and the Mopar Fog Light Kit with the replacement light switch...
Old Oct 27, 2011 | 02:18 PM
SpecialEdJon
well i was ganan do the hella lights behide the grill and just thoght i would be easier to use the fog light hook ups.
Old Oct 27, 2011 | 02:24 PM
HammerZ71's Avatar
HammerZ71
Ah, I actually have my off-road lights wired up to the fog light relay, I never use the fogs so they both come on now when I hit the factory fog light switch.
You can still utilize the fog light relay instead of having to put the one in that comes with the Hellas, the only issue is you can forget using the fog switch to turn them off/on without that trip to the dealer to enable the switch in the PCM.
As you can see, even the factory Mopar kit needs you to goto the dealer so they can soak you $100 to hook up the StarScan and change ONE lousy light setting:
http://www.autotrucktoys.com/ram/Mop...-PRD28585.aspx
NOTE THE NOTE IN THE AD!!!
I have a full DIY on adding the lights in the FAQ section if you need any info on the wiring. I don't follow the Hella instructions because their wiring diagram has you being all on-road legal and has you tapping the high beam wire so the Hellas shut off when hit the high beams. Screw that, blind 'em all!!! LOL...
