Heat Not geting hot
That's very likely going to be a blend door then. usually when the recirc door breaks and falls off the hinges it will cause a major air flow restriction, as that door sits above the blower motor.
All of our air boxes are the same, there are two blend doors, one controls drivers side vents and one controls the passenger side vents. If the control panel on the AC does not have the dual climate controls then both blends are linked together to operate as one. The doors and hinges which control the doors are prone to failure, they are plastic and overtime the power of the DC servo motor will break the plastic parts
