Just installed the K&N Intake, is the POP noise normal?
Old Nov 9, 2011 | 10:43 PM
vikingdiesel's Avatar
vikingdiesel
Default Just installed the K&N Intake, is the POP noise normal?
I just bought the intake with the plastic tube, 57series and WOW what a difference, I immediately saw better MPGs and performance but the sound is whats crazy. It sounds NIGHT and DAY difference. The question I have is the POP noise. I believe its the MDS kicking in and out and I called K&N and they said it was normal. Its like a POP or backfire kind of noise and it pretty much happens when I let off the throttle which is MDS kicks in, so I think I should be fine, also, I have the air pump, so where did you guys install that lower bracket to? The alternator bolt? Cant find where to install the lower saddle bracket on the AIR PUMP models which my 06 has.
Old Nov 11, 2011 | 12:51 AM
vikingdiesel
anyone?
Old Nov 11, 2011 | 01:04 AM
Tom5.7's Avatar
Tom5.7
I recently installed the AEM Brute force on my Hemi and I have no such popping noises. What I do have, however, is the sound of an F-5 tornado when I step on it and then the magnaflows start singing! I love it.
Old Nov 11, 2011 | 01:27 AM
vikingdiesel
i did some research and it talks about LEAN, maybe I should unplug the battery and reset it, did you unplug the battery before installing?
Old Nov 11, 2011 | 02:15 AM
vikingdiesel
I think I fixed it, I just unplugged the battery and connected it back after 5 min and it went away, the popping noise went away, THANK GOD
Old Nov 11, 2011 | 09:17 AM
vikingdiesel
Well i drove it today for about 30min and i got a total of 2 pops, still alot better than before, id be getting the pop everything id let off the throttle, its obviously much better but why am i still getting a pop at all?
Old Nov 12, 2011 | 08:21 PM
vikingdiesel
no one knows anything about this?
Old Nov 12, 2011 | 09:15 PM
HammerZ71's Avatar
HammerZ71
When you say "pop" are you sure you're just not hearing the EGR valve opening and closing? It's got a distinct sound to it that you can't really hear with the "Hemi Hat" on which is actually a baffle for the EGR sound. If this is what you are hearing, it's perfectly normal...
Old Nov 13, 2011 | 11:36 AM
vikingdiesel
Any example of the egr sound? It might be, is it noticeable, its pretty annoying, when does it kick in? this pretty much happens when i let off the throttle
Old Nov 13, 2011 | 12:27 PM
HammerZ71's Avatar
HammerZ71
I would describe the sound as more of a metal on metal tap than a pop, myself.
Egr will close when you let off the gas, so that's probably what it is. I've noticed it's much more pronounced with a CAI that has a metal tube as opposed to plastic. The home-made ones muffle it pretty good as the PVC is pretty thick.
I used to notice it every time but over time I've gotten to where I don't hear it anymore...
