Diy cia question
Old Nov 21, 2011 | 02:14 PM
Teepler916's Avatar
Teepler916
Cool Diy cia question
HOW'S IT GOIN FELLAS,
IM GOING TO BE PUTTING MY CAI TOGETHER SOON AND WAS JUST WONDERING WHAT BRAND FILTER YOU GUYS ARE RUNNING IN YOUR RIGS ?? MAYBE THROW A PART NUMBER MY WAY ?? IM RUNNING 3 INCH TUBEING LET ME KNOW :icon_imnotwor thy:
Old Nov 21, 2011 | 02:28 PM
wishywashy's Avatar
wishywashy
(Caps lock is a key on the left side of the keyboard)
I use a Spectre 9736. SOme say the Spectres are no good, but haven't had an issue. I check the inside of my PVC when I clean the filter and no dust inside (yet).
Old Nov 21, 2011 | 02:36 PM
08HEMI1500's Avatar
08HEMI1500
Spectre here too since its what they had at Advanced Auto when I bought everything. Heard the same about them but I have no problems either
Old Nov 21, 2011 | 03:51 PM
NoLimitzR1's Avatar
NoLimitzR1
You guys do realize you shouldn't be using pvc piping for a cai right? When tubing gets warm it let's off some nasty stuff not good for your engine or health, spend a few dollars more get a metal tube it'll look good and safer. My two cents that's all do as you wish just thought is mention it
Old Nov 21, 2011 | 04:57 PM
wishywashy's Avatar
wishywashy
I researched the heck out of PVC before useing it. I was worried about it softening in the heat. Everything I could find said it was safe. That is unless my engine compartment reaches 250+ degrees, but I think there would be more to worry about than the CAI.
Old Nov 21, 2011 | 05:26 PM
citori13's Avatar
citori13
I used an AEM dryflow filter. Don't have to oil it at all, just blow her off every now and then.
Old Nov 22, 2011 | 05:24 AM
HammerZ71's Avatar
HammerZ71
I use a K&N, but it's 7 years old. Dry flow filter technology has come a long way in 7 years. When I replace the K&N I'm going to try a dry filter next time which will either be an AEM or Amsoil...
Old Nov 22, 2011 | 06:02 AM
ricer's Avatar
ricer
I really don't think the emission of fumes from your pvc is gonna be anything to worry about. I too did a diy cai and I used pvc instead of metal, along with alot of others on here, mainly due to the worry of heat absorption. But I suppose if you were worried about the fumes that could come off a pvc cai then you could make a heat shield, which most of us did, and even go as far as to wrap your pvc in insulation. Just seems like alot of work for something that should never get hot enough to emit the fumes you may be worried about. Just my .02.
Old Nov 22, 2011 | 06:37 AM
HammerZ71's Avatar
HammerZ71
The melting point of Schedule 40 PVC is 360*, I don't think we have too much to worry about. But if you are that worried about it, use schedule 80 (that really thick, hard, grey stuff) which has a melting point of 414*...
Old Nov 22, 2011 | 01:05 PM
Teepler916's Avatar
Teepler916
Question
Thanks for the info guys also Hammer what size AEM filter do you think i know i need a 3" inlet/flange but how long ? 8inch ? 5 inch >?
