Coil Pack rubber boots?
Old Feb 6, 2012 | 06:58 PM
ricer's Avatar
ricer
Default Coil Pack rubber boots?
Does anybody know of a place where I can get just the coil pack rubber boots? I am gonna change my plugs and I was wanting to change the rubber boots inside the coil packs when I do it. Not to mention that with my luck half of them will rip when I go to pull the coil pack off the old plugs anyhow. I have talked to all the local parts stores and all of them are wanting to sell me the whole coil pack at $25.00 a pop!(including the local stealership that wanted $42.00 a piece)
Old Feb 6, 2012 | 08:12 PM
MikeHTally's Avatar
MikeHTally
So far in changing the plugs in the Ram and in the C, I've had no torn boots. $25 for a coil pack doesn't sound too bad - Amazon get $50 each for MSDs (in a pack of eight singles).
If this is the first plug change, I'd say go for it.
Old Feb 6, 2012 | 09:08 PM
bwdakrt's Avatar
bwdakrt
You can get just the boots at NAPA part # BEL702482 $5.49 each.
Old Feb 7, 2012 | 06:03 AM
ricer's Avatar
ricer
I have a 4.7 which I forgot to mention in the opening of the thread, will these still work?
Old Feb 7, 2012 | 07:10 AM
bwdakrt's Avatar
bwdakrt
Nope. Replacement boots for the 4.7 are NA...sorry.
Old Feb 7, 2012 | 05:12 PM
Brandon Anderson's Avatar
Brandon Anderson
Yeah, I ripped a boot when changing the plugs on my '08 4.7L. There are no boot replacements, just new coil packs for the '08. What I did, was purchase a boot for something else that fit onto the coil pack, and I trimmed it down to fit into the hole and onto the plug. Worked fine, and plugged the hole enough to keep crap out. However, the coil packs used on the 4.7L prior to '08 (the ones with only 8 plugs) were used on the Ram, Durango, Dakota, Grand Cherokee and pretty much anything with the 4.7L. There was a part number for those boots, it just would not work for my application.
Old Mar 25, 2013 | 04:46 PM
CharlieHustle24's Avatar
CharlieHustle24
NAPA had some boots for $12. The first two i pulled ripped. I just ordered 8 and I'll change my plugs when they come in.
Old Mar 25, 2013 | 08:33 PM
08HEMI1500's Avatar
08HEMI1500
Or you can just be very careful like I was when changing my plugs to not rip them. That's the cheapest option lol. Mine were suctioned in there pretty tight and took a good amount of force but I didn't rip any. As long as they aren't melted to the plugs you should be ok
Old Mar 30, 2013 | 06:15 PM
CharlieHustle24
Two of mine were in fact melted to the plugs. One took about 20 mins to pick out the rubber. I bought 8 boots expecting all to be as bad. Ended up only needing one. Bought my ram used so who knows how and when the last owner treated it. Almost time for the exhaust side.
