need help upgrading my 4.7
Old Feb 13, 2012 | 04:51 PM
dmoney's Avatar
dmoney
Default need help upgrading my 4.7
Im looking for the best way to add some horsepower. Would like to see what some people have done to theirs.
Thanks
Old Feb 13, 2012 | 05:09 PM
Brandon Anderson's Avatar
Brandon Anderson
Easy and cheap: e-fan and Superchips programmer.
Old Feb 13, 2012 | 05:11 PM
dmoney's Avatar
dmoney
How much horsepower did that add?
Old Feb 13, 2012 | 05:17 PM
Eisengott's Avatar
Eisengott
My 06 has an efan in addition to the clutch fan. Would the efan replace the clutch fan so there would be 2 efans?
Old Feb 13, 2012 | 05:44 PM
SeanW727's Avatar
SeanW727
Three options:
Swap in A HEMI.
Sell truck, or trade truck, and buy one with a hemi.
or check out www.airram.com
They're one of the few companies that has options for the 4.7 motor. Cam, Exhaust, Chip Intake, are some of the easier things to do. Other than that there arent many "Cheap" performance options for this motor. There just not enough of them out there.
Old Feb 13, 2012 | 07:04 PM
Brandon Anderson
Someone did a dyno with the e-fan, it was something like 10-15 RWHP.
The gains you get from the Superchips depends on the year:
  • 2004-2007: 18 horsepower and 20.5 ft-lbs of torque
  • 2008-2009: 48 horsepower and 62 ft-lbs of torque
Old Feb 13, 2012 | 09:09 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Nothing I can think of cheap and massively gainful.
But these will certainly put some "feel" into your truck.
Gears, cams, turbos/chargers
Old Feb 15, 2012 | 05:06 PM
HemiDak-Quad's Avatar
HemiDak-Quad
A Hemi Swap would cost less than 3.k "Junkyard Motor", Low mileage ..That would give you 345. hp ...A 4.7 comes with 245..? To make a 4.7 put out 345. hp would take a $750.00 set of cams , $130.00 Cold air intake $75.00 Electric fan , $1,450.00 in valve springs and head work to handle the cams , Over sized throttle body and fuel injectors , $800.00 Then a Computer chip , $300 ~ $400. This is only an assessment depending on price difference between parts manufacturers..But everyone knows what I would do.."Put A Hemi In it"...There's not a better motor made.."By Dodge"..
Old Feb 22, 2012 | 04:59 PM
Brandon Anderson
The stock efan is for the condenser and does not get changed. Yes, the new efan would replace the stock fan and clutch assembly, and you would then have two efans under the hood.
Old Feb 22, 2012 | 06:59 PM
HammerZ71's Avatar
HammerZ71
Best guy/place I know of for 4.7 power adders would be airram.com. I know a couple of years ago he was regularly beating some pretty heavily modded Hemi trucks at the track with his 4.7...
http://www.airram.com/
