New gauge : )
The aeroforce interceptor with the A pillar. So far Ive found out it reads 26 different parameters from HP to battery volts and a bunch of others.
I also got a white bezel for it to make it match the OEM gauges.
According to the website details it does:
http://www.aeroforcetech.com/products_interceptor.html
Based on the description, it looks very slick. I like the A Pillar mounting as well.
This is exactly what I'm looking for to get my transmission temp without installing an aux probe and gauge. Only thing I'm worried about, is whether trans temp can be read from the OBD-II port. Trans temp is an option on the data logger for my Superchips, but when I select it, there's no reading. Not a zero reading, just nothing there at all. Can you verify whether or not that gauge actually displays a proper transmission temp?
Trending Topics
It will Read trouble codes and also erase them. And also does have a trans temp option but I have to check it again to see if I got a reading.
So many different options I couldn't keep track of them all since I'm still learning about it.
I love it tho. And I just figured out how to set up the led lights to go onwhen I reach a certain high RPM and if my battery volts drop low. Just two of the warning options I picked.
