high mileage survey
Old Oct 10, 2012 | 09:41 PM
  #51
Nate_sorenson's Avatar
Nate_sorenson
117k 02 360 magnum
Old Oct 13, 2012 | 03:23 PM
  #52
05 carvan 3.3's Avatar
05 carvan 3.3
Default 2005 300,1000
just wanted to say I have just flipped overr 300 thousand miles on a 2005 dodge carvan on 10-11-12 I have only had to change the radiator and exhaust manifold gasket. it still driver very nice and don,t use oil. I have found using Lucas gas treatment help keep the fuel injectors clean.
Old Oct 22, 2012 | 04:22 PM
  #53
dw8787's Avatar
dw8787
03 Hemi 4x4 QC - 137,256. Did have to replace the trans, and it is noisey at idle sometimes, but still hanging in there.
Old Oct 31, 2012 | 07:37 PM
  #54
gunbunny2bg4u's Avatar
gunbunny2bg4u
04 2500 181k
Old Nov 4, 2012 | 10:29 PM
  #55
omextreme's Avatar
omextreme
308,xxx on my 2008 ram 1500 4.7... Only issues Diff bearings, front hubs and finally the water pump @298,500.....
Just got my 300,000 mile club plate from Chrysler the other day.
Old Nov 18, 2012 | 10:45 AM
  #56
PRF66's Avatar
PRF66
I got 66,500 on my 2007 Quad Cab, I just had the 60k services done on the truck. Trans, frt & rear diff. brakes, spark plugs, tire rotation, transfer case fluid. Why? Because I intend to run it forever.
Old Feb 14, 2013 | 06:44 AM
  #57
cryder44's Avatar
cryder44
02 2wd has 217,000 on it, and runs like it did the day I bought it. Was 1 owner vehicle when I bought it in 2004. Rock went through grille and busted radiator, had to replace radiator, water pump, clutch fan, thermostat....all because pieces of radiator plastic went into the system. Replaced 1 sensor on passenger side exhaust, and 1 hub assembly on drivers side front. Otherwise, nothing but regular maintenance on this truck! If it died tomorrow, I would still know I have gotten my moneys worth out of this truck! Between me and my two brothers, we have nine Dodge trucks and a Jeep wrangler. Range from 1973 200 4x4 QC SWB to 2005 Ram 1500, and all but one are running. Only one has a motor that is not original, and all except Jeep have over 100,000 on them. Love em!
Old Feb 14, 2013 | 06:51 PM
  #58
MikeHTally's Avatar
MikeHTally
Thread revival: There's a guy on one of the forums who has 350K+ on his 4.7
Old Feb 14, 2013 | 07:49 PM
  #59
Judd360's Avatar
Judd360
My highest truck milage is 275k 98 ram 2500 cummins
Old Feb 14, 2013 | 07:50 PM
  #60
Judd360's Avatar
Judd360
And 135k on my 04 ram 2500 hemi
