Girl Truck Need Help! 2003 Dodge 2500 5.7
Old Aug 15, 2012 | 09:26 AM
  #21
Texbombboy's Avatar
Texbombboy
replacing the pcm fixed it for me
Old Aug 15, 2012 | 11:56 AM
  #22
willdikem66's Avatar
willdikem66
How much did that cost? Did they replace the whole thing or flash a new one
Old Aug 16, 2012 | 07:17 AM
  #23
Texbombboy's Avatar
Texbombboy
i tried to flash it and that didnt work. So i found a company that rebuilds them. I ordered a new one for $400 ,i believe, put it on and sent them the old one. I was having the same issues everybody else seems to was replacing sensors, cleaning the TB, looking at the apps all to no avail. The pcm swap has at a minimum kept it at bay for a year lol. It was an easy swap its on the passenger side firewall right next to the valve cover.
Old Aug 16, 2012 | 12:25 PM
  #24
willdikem66
Idk if you have seen my post every where lately but im having terrible problems from running rich, mpgs down, loping(with out a cam), rough idle and so on... i have done everything it seems like to fix it but still nothing
Old Aug 18, 2012 | 04:15 AM
  #25
blueramhemi's Avatar
blueramhemi
Maybe pull a plug in each cylinder and see if they are all looking rich/lean or just one. If you can isolate it to particular cylinder try swapping coils/wires/plugs/injector to see if problem follows. My problem was fuel pump worn out and contamination (rust) in the fuel rail. It was only acting up under load (fuel starvation). Fuel pressure was still in spec with truck shut off or ideling. Only dropped when pulling a hill or heavy accelleration.
