Old Aug 12, 2015, 02:34 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Dodge Ram 1500 Exterior Guides
Print Wikipost
Got a new Peragon Tonneau cover!!!
Old Apr 18, 2012 | 12:55 PM
cjs4444's Avatar
cjs4444
Default Got a new Peragon Tonneau cover!!!
So after seeing DirtyDog's write up and seeing how awesome the Peragon cover looks brand new i decided to bite the bullet and get a new one myself. Now remember i had the original Peragon cover so my write up wont mimic DD's but im going to concentrate on the differences.
So i got my cover a few weeks ago but i hadn't had the chance to put it on until this past weekend.
Everything was packaged great and easily definable and ready to go.
My first order of business was to take the old cover off, which wasnt too bad. The two sided tape under the plastic bed covers where the worst part of it. So after i got that off i decided to build the frame first. I didnt have any moving blankets so i opted to do it in the grass.
Putting the frame together was easy as i had done before. One of the new things this cover has is it stabilizes itself differently than the old one. The old one used a bar that attached to both ramps. This took away almost a foot of space in your bed. The new system uses a different method so you do not lose space which is a lot better.
After i had put the frame together i mounted all of the L brackets by drilling 4 holes in the inside of the bed rails. i like this method much better where as before the brackets used the existing holes where the 4 open spots are on the bed. Which was ok but very cumbersome to work with and actually mount.
Now as for mounting the frame to the brackets, this is the least fun part of this install. If i had one complaint it would be that the washer method (and even the nut method DD used) is horrible. There are only so many trucks out there and i would think that Peragon could take the time to measure and test and produce a spacer that would work perfect depending on your make and model and not to mention look a hell of a lot better.
So after fighting with that for a bit it was time to install the folding cover. Now the old method had this pin that you had to insert from a TEDIOUS angle. The new one was a god send. It has a push out tab and the cover snaps right in...I will definitely be taking the cover out now that its that easy. I never took the old one out due to how much trouble it was.
So once the cover was attached, i checked for any binding and then mounted the shocks...Now the new shocks have a quick release piece on the end and wow it makes it super easy and the shocks are beefier than the old ones. Upon closing the cover i noticed the strap to pull it shut is heavier duty and the panels themselves seem to be made a lot better.
So with the cover closed i checked for any gaps around the edges but everything was flush...
I also bought the pop& lock piece and it is nice to finally be able to lock my tailgate!!!
I will tell you this if you are looking for a functional tonneau cover then this is the way to go...and it looks awesome as well. This is my second one and i love it.
Rodger and the folks at Peragon are top notch. I even had a lady call me to make sure i got everything the day after Fed Ex delivered it. Now THAT is Customer Service
Old Apr 18, 2012 | 02:13 PM
Peragon's Avatar
Peragon
Former Vendor
cjs4444,
Thank you for the great review, photos and objective feedback!
Did you remove the plastic bed rail protectors for personal reasons or otherwise? They don't have to be removed to install the cover. If you felt the instructions were asking you to do that, we need to change something in the manual ASAP. What do you think we should change?
Thank you for the suggestion on the washers. I will forward that for consideration.
Cheers!
Old Apr 18, 2012 | 05:32 PM
jaydlaw's Avatar
jaydlaw
I just purchased mine today. I am a little worried about installation as it looks like i'll need to cut some of my truck bed liner. in mentions in the instructions that the liner needs to be notched. Could you post picks of the area where that was needed.
Old Apr 18, 2012 | 06:03 PM
Peragon's Avatar
Peragon
Former Vendor
Jaydlaw,
Good afternoon! Excellent question. You will not need to cut your liner...at least I've never heard of anyone needing to. DirtyDog had to "reform" part of the liner so the panels would fold completely, but that's the extent of what I'm aware of. His post discussing this is found here.
The manual speaks of liner modification IF you have a no-drill installation. This information is in the process of changing because we no longer offer no-drill installations. Therefore liner modification is no longer necessary for mounting brackets. Your brackets will mount directly to the inside edge of the bedrail, on top of the plastic bed rail caps, if you have those, and you don't have to cut or remove the rail caps.
Please call us if you have any questions, we would be happy to help!
Old Apr 18, 2012 | 08:42 PM
cjs4444's Avatar
cjs4444
i had to cut my bed liner with the original cover i had...that is why it is cut.
Rodger - i took them off because they started looking bad.
Old Apr 18, 2012 | 10:07 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Very nice!!
Old Apr 18, 2012 | 11:19 PM
Peragon's Avatar
Peragon
Former Vendor
Oh, that's why...whew. Had me worried there for a minute. Thank you for explaining!
Old Apr 19, 2012 | 08:41 AM
dirtydog's Avatar
dirtydog
Moderate User
Looky good my friend!
The washer deal. A specific sized washer would be nice, but not everyone will drill their holes at the same height below the rail or tighten those brackets flush. So, for this, the best solution would be to provide 2 or 3 different sized washers to meet various demands. They only need to be urethane, not metal so that should be cheap enough to provide! Maybe in 1/8" increments? I just measured my "spacers" at 3/8" exactly.
...and customer service is top notch!
Old Apr 20, 2012 | 09:12 AM
cjs4444's Avatar
cjs4444
This is true DD, but i think urethane washers in specific sizes would be awesome.
Old Apr 20, 2012 | 10:58 AM
thumperk15's Avatar
thumperk15
Looks good! I've thought about changing my bedcovers out. I have an ARE at the moment. I do like the style that lock the gate.
