2004 Quad Cab 1500 Hemi Magnum adding Nav?
Old May 2, 2012 | 05:34 AM
suffolk's Avatar
suffolk
Default 2004 Quad Cab 1500 Hemi Magnum adding Nav?
My truck has the factory infinity system, I have seen the same truck with factory Nav...... Question to you guys, is it worth me getting the factory nav unit 399. ? and will it just plug in, or do I go Pioneer Avic or similar for slightly more $$
Always liked factory, but is the truck all set up for the Nav system I wonder ???
thanks in advance for advise
Old May 2, 2012 | 01:45 PM
GeorgiaE30's Avatar
GeorgiaE30
My guess would be no. Is that nav system cd or sat?
Old May 2, 2012 | 03:01 PM
suffolk's Avatar
suffolk
The factory Nav system is CD driven..... i`m just wondering if it would be a plug and go situation in my truck with the infinity sound system, or course I would have to add the nav antenna and cd ........
Old May 2, 2012 | 05:22 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can get a nice and lower model Pioneer double DIN new for 350 and I can custom build you a bezel for it to fit in the dash.
Old May 3, 2012 | 11:42 AM
GeorgiaE30's Avatar
GeorgiaE30
Yeah. It should be a direct fit if its a higher trim level like an slt. Should have all the wires there. If i rememeber correctly in the truck i saw with nav it had the same dash pieces right?
Old May 3, 2012 | 10:54 PM
John  M's Avatar
John M
My only worry with the factory nav unit would be getting modern maps. A lot has changed in the past 8+ years.
Old May 5, 2012 | 12:14 PM
thumperk15's Avatar
thumperk15
I got a nice Kenwood double din for cheap and cut my dash for it. The factory double din matching navi bezel is $100 on Amazon I believe. This is for my later 08 so yours may vary.
Old May 5, 2012 | 01:01 PM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
I considered upgrading to a nav unit when I put in a new stereo a few months ago. I came to the conclusion that I'd only be doing it for the "bling" factor, and when all is said and done I could just get a portable GPS for a fraction of the cost that did more and was more easily updatable.
