behind grill fog lights
Old May 8, 2012 | 10:28 AM
Five.SevenRAM's Avatar
Five.SevenRAM
hey thanks for the input guys, really helpful and i will definetley consider all the ideas everyones posted!
Old May 8, 2012 | 04:21 PM
dirtydog's Avatar
dirtydog
Moderate User
i have 100w Ambers in mine matched up with HID's in fogs and heads. look at my avatar
i also have links in my siggy you can check out.
i can build you a "brite Box" for less than half what they charge. I am an Engineer btw, not a hack.
Old May 8, 2012 | 05:35 PM
Five.SevenRAM
how much would that be? and from reading your posts for the past few weeks i can tell you know your stuff haha. hemi guru over here.....lol
Old May 8, 2012 | 07:11 PM
dirtydog's Avatar
dirtydog
Moderate User
For your 2004, try THIS mod. It's free. It does put more stress on the electrical wiring, but many guys have done it with out any issue's. I think you have beefy wiring and since all Rams prior to 2006 have mechanical relays, it's not as big of a deal as the 2006+ Electronically controlled tipm's that are super sensitive to current demands.
I'd offer to build Brite Box's for 2006+ guys, but if you really want one and want to be 100% safe that's not a problem. I just think you could spend money elsewhere's.
Old May 10, 2012 | 02:47 PM
Five.SevenRAM
what exactly is that mod? is it the one where you can have ur highbeams on with fogs?
Old May 14, 2012 | 07:39 AM
Catchin Zs's Avatar
Catchin Zs
Anybody have the contura illuminated rocker switch(es)?
Old May 14, 2012 | 08:09 PM
dirtydog's Avatar
dirtydog
Moderate User
Yes. It's year specific though... only 2005-prior and not all years have the Relay in same location apparently. If you have an '04, it'll be the same wire routing as what Hammer has done in that link.
Old May 15, 2012 | 03:19 PM
Five.SevenRAM
great, im going to try that out for sure. thanks a lot!
Old May 16, 2012 | 05:53 PM
HammerZ71's Avatar
HammerZ71
The pre-TIPM ('05 and before) jumper wire between the relays works well, but be advised that you now have your fogs on when your high beams are on.
I've since taken this wire out as I wired my off-road lights to the fog light relay so my fog light switch turns on both the fogs and the off-road lights (I hate cutting the dash for switches because they never look "factory").
I tried an experiment in my Jeep in using a wireless relay which works GREAT, especially if you have the HomeLink feature as you can program an un-used button on that to turn on/off your lights. The other nice thing about the wireless relay is that you can operate your off-road lights with a key fob (included) from outside the vehicle, which is a HUGE advantage when you have to use your winch at night.
I've purchased one for the truck and when I install it, I'll re-connect the wire for high-beams and fogs again...
Old May 16, 2012 | 06:06 PM
gHEMImorePower's Avatar
gHEMImorePower
Or you can illegally run HID's in your stock housing like me to where the brights are the equivalent of a cell phone. They aren't blinding bright btw if you go with the bluer ones
