tire question
Old May 13, 2012 | 02:41 PM
SpecialEdJon's Avatar
SpecialEdJon
Default tire question
Sorry if this has been asked before. But will 315/70/17 fit with my 3" level with out a problem?
Old May 13, 2012 | 03:35 PM
itsahemi4x4's Avatar
itsahemi4x4
depends on the wheel offset. Factory rims probably not. Widest tire from factory is 275 which is about 11 inches wide. Your 315's are at least 12.5 inches wide. I know they won't fit on an '07 with stock wheels, but not sure about '05. Sorry.
Old May 13, 2012 | 06:10 PM
SpecialEdJon
i have 245/70/17's on there now and i have AR Fuel Rims. not sure on the offset its ethier +12 or +25
Old May 13, 2012 | 08:51 PM
houseoftoes's Avatar
houseoftoes
Any wider than 12.5 and no they wont fit. I fit 12.5 wide tires and they barely touched
( I mean a penny could just fit in between). Height should not be a problem. I do have a 2008 though.
Old May 13, 2012 | 09:23 PM
itsahemi4x4
His truck should still have the torsion bar front suspension. There should be more clearance around the A arm than on the non torsion bar trucks. Can't remember what year they made the switch but I think it was '06. With his offset, they should fit depending on how wide his wheels are. A 12.5 inch tire on a 9 inch wheel is gonna bulge pretty bad and could have wear issues.
Old May 14, 2012 | 08:25 AM
cjs4444's Avatar
cjs4444
They will fit but it will be tight.....you will probably need a spacer behind there....not much of one but you will need one...
Old May 14, 2012 | 09:07 AM
SpecialEdJon
This is a 2wd so i dont have a t-bar and what would be the biggest tire i could put on without geting spacers or new rims
Old May 14, 2012 | 01:59 PM
cjs4444's Avatar
cjs4444
i would stick with a 285/70/17 and you shouldnt have any issues
Old May 16, 2012 | 06:18 PM
gHEMImorePower's Avatar
gHEMImorePower
It also depends on the tire size. They will never match what size is on the side (they round up). Bfg at should work, I'd look into wheel spacers though they're pretty cheap
Old May 16, 2012 | 06:22 PM
HammerZ71's Avatar
HammerZ71
He's a coil-over, not a torsion front (only '02-'05 4x4s are torsion fronts), and it's gonna be CLOSE! Might go, might not. A wheel with a negative offset would clear it fine.
I would say anything 12" or narrowing in width would be fine with your present wheels...
