Preventative Maintenance questions
Old 08-18-2012, 12:55 AM
08HEMI1500's Avatar
08HEMI1500
08HEMI1500 is offline
RP has additive in it already. As for the OP. You can and should do the TB, spark plugs (no wires on the 08, its just a coil pack and it doesn't need to be changed), the tranny flush (dirtydog has a write up somewhere), and the diff fluid. You'll easily save $1000+ by doing it yourself
Old 08-18-2012, 01:00 PM
kenneymc's Avatar
kenneymc
kenneymc is offline
Yeah I made sure and asked around on here before not using the friction modifier with the RP in my diffs. I actually bought it just in case, but returned it after test driving and all without any chatter. Dirty had done this and gave me some good info about it as he had not needed it as well.
Old 08-18-2012, 01:34 PM
Upstate NY'er's Avatar
Upstate NY'er
Upstate NY'er is offline
well here is my build data, i don't see where it says anything about LDS?? can someone confirm or deny?? I think i am going to try the differentials myself. I'm going to get mobil 1 synthetic 75w-90 for front and 75w-140 for rear. what RTV should i get for sealing the lid back on? Also, do i need to worry about the clips i've been reading about on an 08 1500 hemi?
*AJ Cloth Bucket Seats
-D5 Med Slate Gray
AHC Trailer Tow Group
APAS Monotone Paint
BAZS 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BRRS 4 Wheel Disc Rr Anti-Lock Brakes
CACP Low Back Bucket Seats
CGDS Front Height Adjust Shoulder Belts
CG3S Advanced Multistage Front Air Bags**
CKES Front Seat Area Carpet
CLES Front & Rear Floor Mats
CSPS Passenger Assist Handle
CSXP Rear 60/40 Split Folding Seat
CUES Rear Underseat Compartment Storage
CUSS Overhead Console w/Trip Computer
CVNP Folding Flat Load Floor Storage
DGQ 5-Spd Automatic 545RFE Transmission
DH5S Elec Shift-on-the-Fly P/Time T/Case
DJMS 205MM HD Front Axle
DMHS 3.92 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
EZB 5.7L V8 HEMI MDS Engine
GACS Tinted Glass Windows
GFES Rear Power Sliding Window
GNAS Rear View Day/Night Mirror
GNMS Passenger Side Sun Visor w/Mirror
GPG Power Black Trailer Tow Mirrors
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGAP Hood Insulation
HGBS Dash Liner Insulation
HGDS Deluxe Insulation Group
HGFS Floor Tunnel Insulation
JAYS Instrument Cluster w/Tach
JBYS Instr. Panel Color Keyed Bezel
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JKYS Power Accessory Delay
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JRDP Power Driver Seat
JTHP Power 6-Way Driver Seat
LABS Tire Pressure Monitoring Warning LP
LMAS Halogen Headlamps
LNJS Fog Lamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTS Bright Front Bumper
MDAP Front License Plate Bracket
MF1S Bright/Bright Grille
MGAS Ram's Head Badge
MJB Chrome Bodyside Molding
MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCS Front Bumper Sight Shields
MYFA Bighorn Badge
NAE California Emissions
NFWS 26 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCP Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller
PB5A Electric Blue Pearl Coat
QB5S Electric Blue Pearl Coat
RAAC All Radio Equipped Vehicles
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
REFS AM/FM Compact Disc Radio
RSAS Sirius Satellite Radio
SBAS Power Rack and Pinion Steering
SCFS 4-Spoke Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TTJS P275/60R20 BSW All Season Tires
TZAP Goodyear Brand Tires
WGAP 20" Steel Spare Wheel
WLZC All Aluminum Wheels
WMJP Center Hub
WP2 20" Aluminum Chrome Clad Wheels
XA8S Non Adjustable Pedals
XBM Remote Start System
XBNP Tip Start
XBSS Pickup Box
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XGWP Stain Repel Seat Fabric
XJL Front Hood Protection Shield
XME Under Rail Box Bedliner
X81S Instrument Panel Parts Module
X88S Tire & Wheel Parts Module
X9AP For More Info, Call 888-539-7474
X97P 1-Year Service Provided by SIRIUS
YAAS Build To U.S. Mkt. Specifications
Old 08-18-2012, 11:00 PM
08HEMI1500's Avatar
08HEMI1500
Nope. You would see a line that mentions "Anit-Spin Differential" if you had the LSD. Which is weird that a 4x4 doesn't come with it. But you can always add an aftermarket one!
Old 08-19-2012, 12:27 AM
MoparPaul's Avatar
MoparPaul
MoparPaul is offline
If you have the limited slip
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd
DHAP Lock-Up Torque Converter
DH5 Elec Shift-on-the-Fly P/Time T/Case
DMH 3.92 Axle Ratio
DRBS Corporate 10.5 HD Rear Axle
DSA Anti-Spin Differential Rear Axle
So to answer your ? You don't have to worry about the C-clip in your rear.
Its also funny how they put in a HD front axle and a LD rear axle in your 4wd WTF
Old 08-19-2012, 10:29 AM
08HEMI1500's Avatar
08HEMI1500
Did you take that from a 2500 build sheet MoparPaul?
Old 08-19-2012, 10:38 AM
Upstate NY'er
so are there any concerns i should have with winter driving and no LSD? is only one wheel going to spin in snow/ice?
Old 08-19-2012, 01:01 PM
08HEMI1500's Avatar
08HEMI1500
Yep. You pretty much have a 2WD. Its just one up front and one in the rear lol
Old 08-19-2012, 05:41 PM
Upstate NY'er
So i understand that in 2wd that only 1 rear wheel will spin, but are you saying that in 4wd high only 1 front wheel and 1 rear wheel spins? what about 4lo?
Old 08-19-2012, 05:47 PM
ZWilson07's Avatar
ZWilson07
ZWilson07 is offline
What he means by that is yes you have 4wd but you have open differentials front and rear. So if slip starts occurring which more than likely if you are needing 4x4 it will, then only one tire on the the rear and one tire on the front is going to be spinning and trying to move the truck.
Basically just like even if you had a stock rear lsd, the front is still going to be an open differential, which has the same thing happen in the front. You just happen to be unlucky enough to have open front and rear. It boggles me that they would do that in a 4x4 but if it makes you feel any better, im almost positive the 06 I just bought yesterday is open diff front and rear
Quick Reply: Preventative Maintenance questions
