are 18" rims just as good as 17"
Old Oct 12, 2012 | 05:47 PM
Window Shaker Ram's Avatar
Window Shaker Ram
Default are 18" rims just as good as 17"
hey guys i have a set of 18" rims on my 1500 right now and i hear people always saying 17's are the way to go.... do you think my size (being an inch bigger) will really throw everything off?
Old Oct 12, 2012 | 06:26 PM
PBell78's Avatar
PBell78
I had stock 20's on my 06 ram so in my opinion it's just people wanting to talk smack.
Old Oct 12, 2012 | 06:59 PM
hemi4109's Avatar
hemi4109
Doesn't matter what the rim size is. The overall tire diameter will be what affects your speedo and effective gear ratio etc. What ever stock overall diameter your truck came with can be matched by some tires that will fit on a 17/18/20 or larger for that matter. The 17's just give you more sidewall and are generally cheaper.
Old Oct 12, 2012 | 08:54 PM
drewactual's Avatar
drewactual
You simply can't deflate 20" for offroad traction like you can 17".. a deflated tire conforms to whatever it rolls over, and provides maximum traction.. in sand, it's a fatter footprint/contact patch.. on trails it can grip both sides of a log or rock, as an example..
On road, of doesn't make a bit of difference unless you're riding stupid low profile tires.. stupid low profile tires will cause you to bend a rim if you're not careful with what you run over..
Old Oct 15, 2012 | 10:42 AM
Window Shaker Ram
alright thanks because my 18's are the same circumference as my 17's i just wasnt sure on if the size of the rim really made a big difference
Old Oct 15, 2012 | 11:01 AM
broggyr's Avatar
broggyr
The only difference on the road I can think of is the 18" rims may be a little heavier reducing fuel and braking efficiency; but then again, we aren't exactly driving Priuses (Prii?)
lol
Old Oct 15, 2012 | 11:20 AM
Cthulhu's Avatar
Cthulhu
You can go bigger, just not smaller... smaller rims won't clear the calipers.
Old Oct 16, 2012 | 03:15 PM
Window Shaker Ram
lol
my 18's are actually lighter than my 17's were
Old Oct 16, 2012 | 10:59 PM
SLT8's Avatar
SLT8
My rear 18's are a couple of lbs heavier than my 17's up front but the 18's allow me to run decent size street DR's in the rear full time.
Old Oct 18, 2012 | 10:01 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Just imagine what my 24s and all terrain tires weigh.........
