So I caved...
Old 12-14-2012, 08:01 PM
SC_Ram's Avatar
SC_Ram
SC_Ram is offline
I just got this delivered today.I'll probably install it this weekend...........
http://www.ebay.com/itm/300798961680
Old 12-14-2012, 10:06 PM
08HEMI1500's Avatar
08HEMI1500
08HEMI1500 is offline
Saw that one but it uses the resonator which is the basically the sole restriction on our stock air intakes
Old 12-15-2012, 01:20 AM
Got_Mitch's Avatar
Got_Mitch
Got_Mitch is offline
Im not a beleiver in that train of thought. Plenty of higher end CAI keep on the hemi hats. If it was a true restiction point, im sure they would have taken them off in there building of there CAI product.
Old 12-15-2012, 02:12 PM
08HEMI1500's Avatar
08HEMI1500
What CAI is that? None of the brands I would consider "high end" do that. K&N, BFI, Ramhammer, AirRaid, AEM, etc. None of those use the Hemi hat in their CAI. Not even the Vararam does.
Old 12-15-2012, 03:55 PM
Got_Mitch's Avatar
Got_Mitch
volant doesnt, certain models of other companies dont. Vararam takes it off, by design, how else could they make there dual intake? If I took off the hemi hat, and straight piped my volant, They only gain im getting is noise.
Old 12-15-2012, 08:36 PM
08HEMI1500's Avatar
08HEMI1500
I know there was a member on here that cut open his hat after he took it off and revealed all the chambers the hat uses (to muffle sound mostly) but it also causes a swirling of the air in the hat before it gets into the TB. I'm sure it doesn't affect efficiency too much but I'd just rather the air go straight into the TB
Old 12-15-2012, 10:03 PM
SC_Ram's Avatar
SC_Ram
SC_Ram is offline
Obviously,we all know you'll get resistance all the way from the beginning of a stock intake to the hat.If you take out the box and add bigger tubing made of a polished aluminum,you will get more clean air going thru it and more air equals better performance.For my money,the little bit of gain you will get from excluding the resonator doesn't justify the cost of the big name CAI's,which is why I went with the el cheapo brand.I feel it performs as well as a Volant,K&N or others but I haven't spent the huge dollars for the name brands.Besides I kinda wanted to leave the hat on.I don't much care for the "bare wire" look.Just my 2 cents............
Old 12-15-2012, 11:26 PM
Got_Mitch's Avatar
Got_Mitch
technically you dont want metal tubing. transfers heat way to easily. And I second the Bare wire look. not very clean.
Old 12-16-2012, 03:07 AM
08HEMI1500's Avatar
08HEMI1500
Makes it easier to access spark plugs though. And to clean the TB.
Old 12-16-2012, 07:16 AM
SC_Ram's Avatar
SC_Ram
SC_Ram is offline
I agree......it would make easy access to the TB,plugs, PCV valve etc..... but I have to again default to the trade off value.For the limited amount of times you might have to get to those parts,I would prefer too keep the hat and add the few minutes it takes to remove 2 little 10mm bolts.Besides that,to get to your plugs or to clean your TB,you would (probably) remove the CAI anyhow.Unless of course you don't mind working around and/or under it.To each his own though.
