need help with pre 02 sensor
Old Jan 22, 2013 | 10:13 AM
03 RamHemi Toy's Avatar
03 RamHemi Toy
Default need help with pre 02 sensor
I rebuilt a 03 1500 5.7 put pacesetter full length headers on it with taps for pre cat sensor. I am still running full rich so it wont idle even after heating up the engine? Any advice would much appretiated!
Old Jan 22, 2013 | 12:13 PM
O2's don't have much sway on mixture at idle...... I think you have something else going on there.
Old Jan 22, 2013 | 12:17 PM
drewactual's Avatar
drewactual
agreed...
Q: how do you know you're rich? do you have a wideband on it or monitoring software?
Q: did you contaminate the sensor? for instance, coolant has a really bad affect on those things..
Q: do you have an exhaust leak north of the sensor significant enough to cause the sensor a bad reading? you should be able to hear a leak that bad..
Old Jan 23, 2013 | 03:15 PM
Old Man with a hemi's Avatar
Old Man with a hemi
I also agree, you have some other problem other than the o2 sensors
Old Jan 24, 2013 | 09:52 PM
03 RamHemi Toy
Default 02 sensors found problem
Thanks guys you are correct, I have a intake leak. Do you know where I might find one somewhere other than a dealership,they think they are made of gold instead of plastic!319.34 in Terrell Texas( 03 5.7hemi) salvage yards anywhere within desent driving distance no help or ebay?
Old Jan 27, 2013 | 09:02 AM
03 RamHemi Toy
Originally Posted by drewactual
agreed...
I have two widebands on it. The scanner showed the code 02 voltage high. I have found the problem on the no idle, it was a vacum leak at the intake. I have headers and dual exaust whitout a cross over pipe. Do you know if I need a pre and post 02's spliced into the harness to lower the high voltage reading I'm getting on the scanner?
Old Jan 27, 2013 | 08:57 PM
03 RamHemi Toy
You were right thanks,I have an intake leak. Can you tell me what the small butterfly shaped gaskets are called so I can look them up where the oil inlet is (between 1 and 3 ports and between 6 and 8 ports of the intake? I have looked at all the local parts stores here and they all show the gasket sets with only the 8 port gaskets??
