Diesel turbo on a Hemi?
Old May 24, 2013 | 06:38 PM
sgpwayne's Avatar
sgpwayne
Oh yeah don't forget a intercooler to keep it cool. You should have plenty of room just take your time and plan it out
Old Aug 7, 2013 | 10:52 AM
trn579s's Avatar
trn579s
Bringing the thread back to life, I'm starting to put all of the pieces together to throw a Holset HX35 turbo on my 2004 Dodge Ram Hemi as a remote mount turbo system (same as the STS kit, http://ststurbo.com/dodge_ram_hemi_).
Here is a similar setup as you see in this video on an older 5.9:
I'm only going to run around 5psi, with no intercooler at this point. First, I'll start with an AEM Wideband FailSafe gauge (http://www.aemelectronics.com/wideba...safe-gauge-84/) to monitor my air fuel ratio on my stock hemi. Later it'll serve as my AFR and boost gauge. If it runs lean under boost, I'll throw bigger injectors and a 2bar MAP in it, that gauge will make sure I'm adding the power safely.
I'm not super worried about towing since the turbocharger is mounted aways from the engine keeping temperatures much cooler. Yes, I know it won't be as efficient as a front mount turbo, but it's a truck not a racecar, so I'm not worried about that. With proper sizing, turbo lag is not going to be a huge issue.
Old Aug 7, 2013 | 11:00 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I personally, would put the turbo as close to the engine compartment as possible to increase air velocity and reduce temps. I dunno why the guy in the vid. had his so far back there.
Old Aug 13, 2013 | 10:03 AM
gHEMImorePower's Avatar
gHEMImorePower
I didn't even realize my thread was still going haha. That sounds wicked I'm back on the idea now!!! But I don't know how to install it
Old Aug 13, 2013 | 11:07 AM
trn579s's Avatar
trn579s
It's actually not all that difficult, just putting the pieces all together and some exhaust fab (which I'll gladly hand over to someone else). I'm putting together a parts list for this and planning on having a couple different columns, cheap, midrange, and top shelf so I can look at all of the different options and what they will cost.
I'm not new to forced induction, ran a ProCharger at 14psi intercooled on an older Chevy 350 Tuned Port for years, so I have some experience in this area... first time doing forced induction with a turbocharger though. I sold the old ProCharger because it was far too loud for my daily driver truck, really loud constant whine.
Old Aug 13, 2013 | 11:41 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Old Aug 13, 2013 | 11:43 AM
trn579s's Avatar
trn579s
VWandDodge just solved all emissions problems!
Old Aug 13, 2013 | 06:34 PM
KasperR34's Avatar
KasperR34
Originally Posted by VWandDodge
Seems Legit
Old Aug 13, 2013 | 07:31 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
It works on paper. Someone needs to carry out the design on his truck and report the results.
Old Aug 13, 2013 | 07:36 PM
KasperR34's Avatar
KasperR34
For the performance oriented
