Diesel turbo on a Hemi?
Old May 15, 2013 | 12:00 PM
gHEMImorePower's Avatar
gHEMImorePower
Default Diesel turbo on a Hemi?
I've read that diesel turbos can work fine on some gas engines cuz the type of fuel doesn't effect a turbo. I don't even think it'd fit on a hemi but heck thought I'd ask.
Old May 15, 2013 | 12:39 PM
4.7Ram's Avatar
4.7Ram
you no ive wondeed the same thing, we would prly not get any performance out of it but i always thought attaching one side to the intake tube and put a filter on the other side and just drive around to hear it spool
Old May 15, 2013 | 01:19 PM
Jareski's Avatar
Jareski
Or you could mount a Dyson with an air cleaner and run a switch to the interior. It'd be spooling' 24/7. Scare off some bow ties and ovals for sure.
Old May 15, 2013 | 02:00 PM
atlaticblueram's Avatar
atlaticblueram
If you are talking about a stock cummins Holset HX35 or HY35 turbo a hemi would probably spool it. Downside is towing with a turbocharged GASOLINE engine can create too high of an EGT (exhaust gas temp) and cause serious issues. If you can figure out how Ford runs the eco boost and keeps EGT's down while towing you would be fine. The main thing with the eco boost is it is twin turbo and the turbos are quite small.
Old May 15, 2013 | 03:16 PM
jnellydodge's Avatar
jnellydodge
And they like to burn out if you actually use them to tow.
Old May 15, 2013 | 04:40 PM
gHEMImorePower
Well I don't tow and like the other guy said I just love to hear them spool
Old May 18, 2013 | 08:20 PM
Jmn822000's Avatar
Jmn822000
There are people using the HX and HY35 snails on Hondas with excellent results. I'm confident that if a 1.6L can spool up a turbo that size with 8.5:1 compression to full boost at 3000rpm, then a Hemi that's almost four times the displacement can spool it with ease.
Old May 23, 2013 | 05:55 PM
gHEMImorePower
Hmmm I might just do this. Has seriously nobody on this forum not tried it? I don't wana be a guinea pig lol
Old May 23, 2013 | 07:09 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
You could do a remote turbo with an intercooler. That might keep the air charge down cool enough. But I wouldn't tow with it.
Old May 24, 2013 | 06:33 PM
sgpwayne's Avatar
sgpwayne
You can adapt just about anything with money and time. Towing would be no problem, just make sure you have the proper waste gate and a pyrometer guage to keep it under control.
