Tire size question.
Old Aug 1, 2013 | 09:09 PM
farleyrf's Avatar
farleyrf
Default Tire size question.
Hello, I have a 2002 Dodge Ram 1500 4WD, with a 3" Body Lift, and i was wondering what size tires I could run with stock gears? I was looking at 35's or 33's. but I've heard that the stock gears wouldn't run 35's, but would they be able to run 33's?
Old Aug 1, 2013 | 11:36 PM
SLT8's Avatar
SLT8
it will run either way. just going to take some time to get up to speed.
Old Aug 2, 2013 | 06:12 AM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
I have 33" A/T tires with a 3" BL. Take into consideration that the stock GoodYears on the 20" wheels are roughly 33" tires (though not as wide as most off-road/AT tires). You can easily fit 35" tires no problem. Optimally you'd want 4.56 with 35's, but you can get by alright with stock gearing.
Old Aug 2, 2013 | 10:26 AM
farleyrf's Avatar
farleyrf
Thanks! I am planning on getting 305/70/17 tires, and just wanted to make sure I would be able to run them without having to re-gear it. I was also wondering is there anything else I should watch out for? Should I watch anything else, as far as diameter wise, or anything. I read that a more than 3% diameter difference can cause brake failure. Is that actually a common occurrence? or more on the rare side?
Thanks!
Old Aug 2, 2013 | 10:28 AM
farleyrf's Avatar
farleyrf
I am also using the stock rims, will I need spacers, or anything? Just want to make sure everything is working correctly, and installed correctly when i get them!
Old Aug 8, 2013 | 10:30 PM
farleyrf's Avatar
farleyrf
I installed the tires, and they drive great! How-ever, when first pressing on the gas, like, before the truck even gets over 5 or 10 MPH, there is a deep vibration that feels like something is rubbing against the tire... I checked the tire, and it isn't touching anything. it is extremely close to the upper ball joint, but it isn't touching it, or rubbing against it that I can see. It is PRETTY Close though... like... not even a inch away. It also does it when slow turning, but does it every-time when I first start accelerating. Any Ideas?
Old Aug 9, 2013 | 01:48 AM
Chet Ubetcha
What kind of tires are they? If they are aggressive tires, you may just be feeling the tread on the ground.
Old Aug 10, 2013 | 10:39 AM
farleyrf's Avatar
farleyrf
They are Goodyear Wrangler MTR with Kevlar Tires. IMG_0545_zpsc16d779a.jpg?t=1376145328
they are aggressive tires, but It doesn't feel like a tread feeling.It feels like something is grinding, when I turn at slow speeds now too. it's also vibrating the steering wheel while driving on the highway now I have no idea what it is. It might be me just feeling the tread, I'm not sure. Never had any kind of decent tires before! lol. I'm more of a mechanical person, not associated with tires...lol.
