Projector Headlight Retrofit Questions
I did mine, but sorry, no write-up. I think there's a headlight procedure in the FAQ section but it's for painting I think.
I made mine fully adjustable. Most shops just RTV the housings in a set position once they mark where the beam pattern lies on the wall. There are YouTube videos of this stuff.
It's an 05. So far I have a set of regular stock headlights, morimoto (sp) mini projectors and the hid kit. Is there anything else I need to get this to work? Also, I have been running these hids in my headlights for a couple years so I know it will work with my computer system without the need for resistors and things like that.
Well, the quality of the ballast is what determines if you need resistors..etc for the lights. Very few wont need resistors. I imagine the new bulbs are D2S style versus a retro fitted H13 bulb base. You'll need different ballasts for those.
I would run those on a relay harness so they don't go out when you use your high beams.
I ran separate relays for each headlight so I will at least have one headlight if my relay goes bad or fuse pops..etc
http://shop.retroshop.us/ProductDeta...roductCode=MH1
