TCCM replacement
Old Feb 19, 2020 | 03:27 PM
Derekwh's Avatar
Derekwh
Default TCCM replacement
Hi, has anyone replaced their TCCM? Is it possible to do without taking the dashboard apart?
Old Feb 19, 2020 | 05:21 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
You should only need to get access right next to the steering column, the large panel under the column (or just going from underneath) should be adequate. Have you researched to see where it actually is?
Old Feb 20, 2020 | 01:28 PM
Derekwh's Avatar
Derekwh
It looks like it is visible through the port on the left end of the dash. I guess my question is can I get it out without taking apart pieces of the dash. It seems to be under several layers.
