How to Choose the Suitable LED Bulbs for Your Vehicle?
Old Oct 25, 2024 | 04:45 AM
LASFIT's Avatar
LASFIT
Former Vendor
Default How to Choose the Suitable LED Bulbs for Your Vehicle?
Planning to replace your OEM halogen/incandescent bulbs? Chances are, you’ll check out some recommendations on social media first. Maybe you’ll browse forums for reviews or look up videos on YouTube for the same year, make, and model as your vehicle. But here’s something you might not have considered: trim differences can significantly affect the products you need!
It’s pretty common to find variations between trims, such as one having OEM LED bulbs and another using OEM halogen/incandescent bulbs. This is important because aftermarket LED bulbs are designed to replace OEM halogen/incandescent bulbs only.
However, even trims that both come with OEM halogen/incandescent bulbs can require different bulbs. For example, with the 2021 Chevrolet Silverado 1500, the front turn signal bulbs vary depending on the trim:
The WT, LT, RST, and High Country trims use T3-7443A LED bulbs for the front turn signals.
The Custom and Custom Trail Boss trims, on the other hand, require T3-7443A-CK LED bulbs.
In this case, the difference lies in the Non-CK and CK versions of the front turn signal bulbs.
But trim differences aren’t the only factor. Even the design of specific parts, like fog lamps, can make a big difference. Take the 2016-2018 Ram 1500, for example. Its fog light bulb size changes depending on whether it has vertical or horizontal fog lamps:
Tire Wheel Vehicle Grille Automotive lighting
Ram 1500s with vertical fog lamps use a 9006 fog light bulb.
Ram 1500s with horizontal fog lamps need an H10 fog light bulb.
So, even for the same year, make, and model, the fog light bulbs may be different.
To make sure you get the right fit for your vehicle, we recommend using the YMM search tool on Lasfit’s website to find bulbs that match your vehicle. You can also reach out to us directly through our “Speak to Us” feature on the website, and we’ll help you find the suitable bulbs.
Rectangle Font Parallel Circle Pattern
If you’re planning to replace your OEM halogen/incandescent bulbs soon, feel free to drop your YMM and trim details in the comments below, and we’ll help you find the right LED bulbs for your vehicle!
Old Oct 26, 2024 | 09:55 AM
jjolson68's Avatar
jjolson68
this is an ad. You can find the search frame on any headlight site. Don't buy into supposedly helpful information when it's just trying to sell you something... Do your research...
Old Oct 26, 2024 | 11:50 AM
Moparite's Avatar
Moparite
Lastfit is a sponsor and they get a small kick back from the forum. It would be interesting to see actual sponsors that make stuff we NEED rather than the same garbage that's overflowing on ebay. I posted before on another forum and possibly this one that these sponsors try to sell stuff for a "Dodge", But if you actually look they offer one item for a Dodge and slew for brand X. And then they say they are "Dodge" specialist. If you are looking for something for your vehicle you will find other options than the sponsors you see on the forums. Shame my adblocker doesn't block their posts also!
