Does anything squeak/rattle/creak on your Ram?
06 ram 1500
there is a plastic shroud around the base of the seat on the passenger side
(no shroud on drivers side for some reason) it was rattling against the seat frame
as it is not attached very well
I put a piece of velcro (soft side) on the part of the seat frame in contact with
the shroud
this tightened up the shroud an eliminated the rattle
Josh
also noticed the front windows make a occasional creaking sound over bumps- when they
are all the way up- no idea on this one
the shroud
Josh
I have 61,000 kms on my rig and she is squeak free!.........the only thing I have had to repair was the EGR valve and that was replaced under warranty while I waited in the wating room.
My 02 1500 dont squeak much, theres a little bit of a clunking when im goin in reverse in four high, but it goes away in four low...dunno what thats about, if it breaks ill fix it. i guess, but the break pedal squeaks, and the interior door panels squeak like nobodys buisness, i read in here somwhere, some guy put electrical tape on the doors under the panels.....that sounds like an i dea worth pursuing.....sounds like a good days work to me.....
ORIGINAL: Johndcjr1989
when i drive with my radio off or on low i can hear my sliding rear window squeaking. it drives me CRAZY! i guess its just the molding around the window rubbing and squeaking. anyone else have this?
ORIGINAL: fd3sxiong
get underneath the gas pedal or the brake pedal and spray some WD40 onto where the spring is at. See if that'll cause the noise to go away.
Try silicone spray. It does not attract dirt. It's a great lubricant. It has all kinds of great uses. Just pick up a can at the local auto parts, or hardware store and read the label for all it's uses. It works great on all the rubber door seals and other rubber parts of a vehicle to keep the rubber fresh and pliable for years.
99% of the time i have my radio up so i cant hear my rear glass squeaking but when driving with my parents or in other situatuions when i cant turn it up its annoying as all get out. i never use the rear glass anymore(used it all the time when i got it but not anymore) but 450 bucks is a little too expensive for me to justify replacing it. maybe somebody will throw a rock through my back window and i can get insurance to replace it. lol
