TOW/HAUL???????
Old Mar 30, 2007 | 10:01 PM
tailgatedrinkin's Avatar
tailgatedrinkin
Default TOW/HAUL???????
ok so maybe a dumb question, but on the ram forum i was reading and some people were saying that you only use tow/haul when pulling a load in (hilly conditions) i have always thought you use tow/haul ANYTIME you are pulling a trailer. could anyone clear this up for me.???
Old Mar 30, 2007 | 10:48 PM
djr04's Avatar
djr04
Default RE: TOW/HAUL???????
I would use tow/haul any time I am pulling something, and use OD off in really hilly areas. I would think you would risk wearing out the 5th gear if you only used tow/haul in hilly situations.
Old Mar 31, 2007 | 04:23 AM
motorider228's Avatar
motorider228
They just shut off different sets of overdrive gears. tow haul shuts off the 4th overdrive gear and overdrive off shuts off all overdrive gears.
Old Mar 31, 2007 | 11:10 AM
tailgatedrinkin
dont they also make the truck take longer to shift through the gears??
Old Mar 31, 2007 | 05:51 PM
motorider228
Yes it takes longer as it only uses the 12345 gears and not the 2,3 prime gears and the 4,5 overdrive gears. It uses the best gears and strongest clutches.
Old Apr 1, 2007 | 10:27 AM
FD929's Avatar
FD929
Yes, tow/haul keeps the transmission in each gear into upper revs, keeps the rpm increase smooth as to not jerk the load and also keeps it from upshifting when going down steep grades to serve as an engine brake. I was highly impressed by my new baby while pulling a double axle 16' trailer with 4 quads and the bed full of camping stuff, ice chests, and a generator. I actually felt like tow/haul served a purpose vs my old chevy.
Old Apr 1, 2007 | 11:20 AM
tailgatedrinkin
yeah thats what i thought, so in summary when pulling any trailor keep tow/haul on the whole time.
FD9292- what kind of truck do you have, and is your trailer enclosed?
Old Apr 1, 2007 | 04:08 PM
NYPANAMA42's Avatar
NYPANAMA42
Good question. But what is the OD button for then? I have an automatic transmission, and have the OD button.
Old Apr 1, 2007 | 06:16 PM
motorider228
the O/D off button on your 02 serves the same purpose as our tow/haul it just doesn't keeping it revving as much. If you are under a load or towing turn your over drive off.
Old Apr 1, 2007 | 08:01 PM
tailgatedrinkin
so on the newer models what are the difference between the TOW/HAUL and O/D OFF ?????
