true tire pressures
Old Apr 4, 2007 | 02:14 AM
ghostdog1's Avatar
ghostdog1
Default true tire pressures
have a 2004 with 275/55-20's the door says one pressure and the tires say another, what have you gays found to be the correct pressure for this tire for proper tire wear. thanx in advance
Old Apr 4, 2007 | 02:23 AM
reiderr's Avatar
reiderr
Default RE: true tire pressures
Use the pressure recommendation on the door sill as a starting point. It represents what DC believes is the best pressure for normal conditions (35 psi). The pressure on the tire representst the maximum pressure possible in the tire. Typical LT tires run in the 44 to 50 psi range. Inflating your tires to their maximum pressure will lead to a very harsh ride with a lot of center wear. Some folks push the front pressure to 40 psi and leave the rears at 35 psi when operating with no load. Carrying a full load, towing with a high tonque weight, etc. would probably indicate a higher rear pressure, maybe 40 psi. I run empty most of the time and have both front and rear pegged at 35 psi.
