3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I'm getting ready to tackle what looks like the broken defrost door TSB on the wife's 2003. Gotta pull the dash and the whole HVAC unit. I'm just wondering if anybody has done this yet and if they could offer any tips. Thanks in advance.
If your just looking to get to the hvac controls (assuming its the same as my 04) all you need to do is remove the bottom section below the steering wheel (2 torx screws on the bottom and 2 snaps at the top) then remove one screw from the hangar thing on the right side of the controls and the whole cover in the center will just pull out. Just be very careful not to break any of the clips when pulling it off. Make sure you pull it off straight and not at an angle.
I should probably edit that post, i found #12 under a seat while detailing the inside. Still not to bad, read a post where someone had 20+ so i feel good, not great, but good.
haha i had 0 its easiest to set the ones you pull out from one section in one pile and another in another pile and so on or even lay them right with the piece they hold in.
