MPG Sucks!
Old Apr 25, 2007 | 06:41 AM
05_FL_RAM's Avatar
05_FL_RAM
Default RE: MPG Sucks!
wow...I have just the factory 20's and stock rubber.....a cheap eBay CAI unit.... power wire and grill mounted intake scoop.
with my 05 HEMI QC2X4 Auto...I get 15+ in the city and 19~21 on the highway.
some people talk as if they are surprised at the MPG these trucks get......WTF...was this an impulse buy for you? The 5.9 is right up there with the v10 trucks in gas consumption.......this CAN'T be new information for you..... ???
being a 2002..it might be time to review a few servicable areas of the drivetrain....tranny?
cut back on the mods...and try a different "style" of riding....accelerate gradually....don't race up to the speed limit.
some good ideas above...try the manual hubs....and perhaps a smaller tire?
Old Apr 25, 2007 | 10:17 AM
HankL's Avatar
HankL
a very long read
but with dozens of ideas that work on Rams:
https://dodgeforum.com/m_447500/tm.htm
In a nutschell:
learn about tire rolling resistance,
learn about the drag of the wind
consider a block warmer
slow down.
Old Apr 25, 2007 | 01:07 PM
truckin151's Avatar
truckin151
I never use a light foot when excellerating (rpm's are always between 2-3k)and I get a better mpg average than when I'm trying to go slow while excelleratingto the speed limit+(specially on the highway). I average around15mpg onside streets and around 16mpg on the highwayin my 05' 1500 RC SB with the 5.7L HEMI andI dont have MDS. Giveyour truck a complete tune up, go with synthetics for your fluids, invest in a good exhaust system,make sure your filter was made for your truck and make sure it's clean,make sure your tires are properly inflated to the correct psi,when excellerating try to keepyour rpm'sunder3k, andinvest in an electric fan. Other than that man I dont know what else to tell you.
Old Apr 25, 2007 | 01:25 PM
nathanp's Avatar
nathanp
ORIGINAL: 05_FL_RAM
i dont see how u guys can get 20+ mpg with your truck...... right from when ive had my truck till now ive never gotten better then like 16 and sicne then have done intake, exhaust, programer and nothing has got it anywhere close to 20 mpg
Old Apr 25, 2007 | 02:34 PM
HighDuke1911's Avatar
HighDuke1911
ORIGINAL: nathanp
ORIGINAL: 05_FL_RAM
thank you!! lol. i can barely get to 13. lol. well, i did reset my MPG thingy on the freeway and i was at 22mpg with my MDS going. lol. but uhh... other than that, im under 15, all the time. but then again, i only have about 2500 miles on my truck. lol. well, i will do exhaust soon. a tonneau cover, K&N, and synthetic oil. hopefully that'll all do the trick to put me up at 17-20mpg. lol.
when i accelerate, i go slowly. i go up to 2500, then when it changes gears, i try to stay at 2500 and not go over. i keep my RPM's around 1500-2000. thats when my MDS is kicking in. so yeah. i have ****ty MPG so far. i really hope it gets better. i guess thats what you get for having such a badass truck, bad MPG. whatever. i understand its a truck, i understand ALL trucks have bad MPG, especially dodge. but im complaining, but i know that its normal. but still, i like to complain. i just think we are all doing whats natural with this situation. so im not gonna go say "oh, why you complaining, its a truck, blah blah blah blah!" but i do think that archer is getting the MPG he should be getting with his truck and accessories. it make sense to me at least.
Old Apr 25, 2007 | 03:14 PM
tinyfxds's Avatar
tinyfxds
16.5mpg with 02' 4.7L. The last two weeks anyways. I try not to go any more than 5mph over the limit and coast to stop lights. My superships seems to work a little. I can't wait to get my exhaust redone cause with the straight pipes on it is getting worse gas mileage
Old Apr 25, 2007 | 06:04 PM
Ricker's Avatar
Ricker
I think an electric fan would do you a lot of good. Anything to make the motor work less helps. Also look into under drive pulleys and a lower t-stat.
Old Apr 25, 2007 | 06:51 PM
syn65's Avatar
syn65
Personally i get between 15 and 19 on the highway(depending on where i'm going, for some odd reason i get better mpg in the us then i do in Sasakatchewan. Go figure). But i'm always on the lookout for something that will help. What are the manuel hubs mod ? and does the t stat really work ?
[align=left] [/align]
Old Apr 25, 2007 | 06:56 PM
CarGuyOhio's Avatar
CarGuyOhio
20MPG is obtainable, but not as an average, only on the highway with MDS and the cruise set to 60-65ish. I have pulled off 18.5 with my 05 4x4 Hemi on a 100 mile highway trip.
You are not going to do much better with that 5.9.
Old Apr 25, 2007 | 07:02 PM
HankL's Avatar
HankL
If you know what speed you intend to get up to
it is actually more efficient for the nearly all engines to
accelerate at 70-85% of full throttle
up to an rpm a few hundred rpm short
of the rpm where maximum torque is generated.
Once you get up to your chosen speed
shift into a gear that keeps you near 70-80% throttle
but at the lowest possible rpm.
But don't skip over the part above that reads:
"If you know what speed you intend to get up to"
because if you choose to go a slower speed
you will get a better mpg.
High cruise speed = Low MPG
There is even a technique used in 'MPG Marathons'
where contestants with manual transmissions
accelerate at 80% throttle up to 45 mph
then coast to 15 mph
then accelerate at 80% throttle back up to 45 mph,
over and over and over.
