MPG Sucks!
Old Apr 24, 2007 | 09:35 PM
archer417's Avatar
archer417
Default MPG Sucks!
I have an 02 Ram 1500 quad cab 4WD with the 5.9L V-8. I have a K&N air filter on it. I have tried the "tornado" slipped into the intake and I have tried the superchips programmer. I get 13.5mpg hiwaytops on a good day and about 11 avg. Does anyone know of anything else to try? There is no room for one of the intake adapters like the helix. The intake from the K&N system is tight against the body. Any suggestions would be greatly appreciated. Thanks[:@]
Old Apr 24, 2007 | 09:40 PM
HighDuke1911's Avatar
HighDuke1911
Default RE: MPG Sucks!
well, im getting 11.9 right now and i have a featherfoot. all stock too. and my truck has the MDS in it. plus, its a truck, you can texpect more than 20 mpg on it. and i think 13.5 is good for a 2002 ram 5.9L with the accessories you have.
Old Apr 25, 2007 | 12:28 AM
HuntinHanson's Avatar
HuntinHanson
you could try an exhause upgrade, if you can keep your foot out of it it may help a bit
Old Apr 25, 2007 | 12:35 AM
schmedly's Avatar
schmedly
I had a '98 5.9 4x4 Quadcab and my average was less than 11 and highway best was less than 14. I used synthetics, a light foot, and conservative habits. it won't get better. That said, after 9 years and 131K, the only engine problem that was not "routine maintainence" was a water pump.
Old Apr 25, 2007 | 01:02 AM
JimmyDiablo's Avatar
JimmyDiablo
depending on miles, perhaps your catyletic converter is getting clogged. Can do a tune up and look into all the bolt on's like electric fan, manual hubs. things like that.
Old Apr 25, 2007 | 01:09 AM
HighDuke1911
well, use some of that stuff that you add to the gas tank for "better mpg" becasuse itll unclog the gas lines or whatever theyre called.
Old Apr 25, 2007 | 01:41 AM
Duso02's Avatar
Duso02
It sucks, but Dodge is well known for the worst mileage of the V-8's. My Hemi avgs 11. Don't waste your money on infomercial crap. Thereis enough tests and reviews showing how little they work. You might squeeze 1-3 mpg by addding a CAI and free-flowing exhaust. The only real way to improve mpg is drive it real easy, keep it tuned, watch your air pressure, and don't lift it adding big tires, etc. I know, I know, what's the point of having a truck? My solution, I moved closer to work.
Old Apr 25, 2007 | 03:27 AM
redram5.9's Avatar
redram5.9
Thank your lucky stars, I would die for those numbers. I have the same truck and I am getting 9-10 mpg, but I am running 35" rubber with the stock 20's.
Old Apr 25, 2007 | 03:54 AM
dirtydodge02's Avatar
dirtydodge02
If it makes you feel any better at all, I have an '02 1500 4.7 with a CAI and this last weekend I had to make a 300 mile road trip and averaged 13.6 mpg. 140k on the odo though...
Old Apr 25, 2007 | 04:05 AM
HighDuke1911
thats not that bad. im gettin UNDER 13 with my HEMI w/ MDS.
