K&N Drop in Air Filter
#21
RE: K&N Drop in Air Filter
ORIGINAL: DonG
The only thing a K&N drip in will do for you is remove cash from your wallet and allow more dirt into your engine.
#22
ORIGINAL: Duso02
Amen to that brother. An old mechanic once asked me this when I installed one: "How can something that allows more air not allow more dirt?" Good question nobody has ever answered.
ORIGINAL: DonG
1. K&N filtersprovide a LARGER SURFACEAREA than a stock paper filter, this allows more air flow (so easy a cave man could understand it)
Ok now some other stuff:
1. Most engine wear is caused by particles 10 to 20 microns in size. K&N cotton filters capture all but 2% (maybe better)of these little monsters.
2. The K&N filters we are talking about are made of multi layered Cotton, a material known for its ability to absorb. Question I have here is do you wear Paper underware? What happens to a paper element if it absorbs a lot of moisture or gets wet? Well that could let a mess of alarger than 20 micronsized foreign objects down the throat of your beast.
3. If you follow the instructions on recharging a K&N air filter - no oil will get sucked intoyour airsystem. It will last 10 times longer so better for the environment. My trashcan will have 1 for every 10 of yours. Also a larger dent in Your wallet not to mention the environment.
4.So my Cotton K&N is within 1% of a Paper Fiber filter on filtering. (I find this totally acceptable)
5. What is the % of your Paper Fiber filter vs my K&N on Flow?
#24
HankL... thank you for answering my question on the other post. You seem pretty against any mod out there. What mods, if any, do you run with? Are you an engineer or something, orjust someone that sits in frontof a computertoo often? (Don't take this as an attack... I am honestly curious)
#26
ORIGINAL: Pappy_FB
Being Old and a Mechanic, with a little bit of rocket science under my belt let me answer that for you. And as for the rocket part we don't use paper filters on any of those systems. Unless you count the paper work.
ORIGINAL: Duso02
ORIGINAL: DonG
The rest can be disputed by reading Amsoils website or AEM's, they all say their filter is more efficient then K&N's and vice versa. It's like listening to politicians!
#27
After working with filtration systems for treatment plants and water plants for the last 3 years I went with the AFE system mainly because it has the largest filter I have ever seen in an intake and can filter down to 1 micron. The technology over the past few years since those studies have improved dramatically. And for those of you guys who dont like the oiled filters many companies are coming out with dry reusable dry filters that filter out the same as there oiled counter parts. Just do your research before you add anything to your truck.
#28
DC Performance told me that the K&N drop in is a very good thing to do to the SRT-10'S.
They work on all VIPER power cars and trucks.They also work on VIPER race cars. They
are small time shop. I would think they know that they are doing. I don't have the drop in, I
have the CAI.
have the CAI.
#30
