2003 Wheel Question
Old Apr 26, 2007 | 03:00 AM
hozie's Avatar
hozie
Default 2003 Wheel Question
It is time for me to change my tires. I have stock 17" rims with stock 275/70/17 Wranglers. I plan to go to a 285 BF Goodrich All-Terrain T/A or perhaps a 295 Nitto Terra Grappler. My question is this: I would actually like to replace my 17" rims with some 16"'s and put the new tires on those. Question is, I read somewhere that due to the brake size on the 2003 4x4 it was necessary to use 17" rims to get over the caliper. Any truth to this?
Old Apr 26, 2007 | 03:15 AM
DeWalt378G's Avatar
DeWalt378G
Default RE: 2003 Wheel Question
Yes. Also, I think I read somewhere here that even some aftermarket 17's may give you trouble. Why do you want to go 16?
Old Apr 26, 2007 | 03:33 AM
hozie's Avatar
hozie
There is no real good reason why I wanted to go with a 16" rim. I want to replace the stock ones I have because they have gotten pretty caked with road tar from the last two summers. I kind of like the lokk of a smaller rim with a taller tire so that is pretty much what I was thinking. I was hoping to go with someething like a simple brushed (satin) finish Weld wheel. Guess I better not chance it too much. All I know is, replacement tires on the 4x4 off road trucks are expensive,
Old Apr 26, 2007 | 03:39 AM
DeWalt378G's Avatar
DeWalt378G
If you want to stay small I would go 18. There is a huge selection of rims out there for 18. Since the fad is 20+ you could probably get some 18's real cheap too. That way you can put the money into those Nittos. Those are awesome tires. Wish I got them myself.
Old Apr 26, 2007 | 03:40 AM
HighDuke1911's Avatar
HighDuke1911
yeah, ditto on 18's. cheaper than usual.
Old Apr 26, 2007 | 03:48 AM
hozie's Avatar
hozie
Right on. Well, maybe I should just see if I can have my stock 17's refinished to get all that tar off. I amhesitent to go as big as 18" rims because I think they would look out of place on the truck with "4x4 OffRoad" down the side. I dont know, maybe I am wrong, I was just thinking that going with 18" or larger wheel gives it more of a "pimped street rod" truck look than what I am going after....or I could just be crazy!
Old Apr 26, 2007 | 03:59 AM
DeWalt378G's Avatar
DeWalt378G
I went from 17 to 20 and it doesn't look bad at all. I have black centers though, so it makes them look smaller than they really are. A lot of people said to me, "so you got 18s." If you go 18 you will barely notice it especially with larger tires.
Old Apr 26, 2007 | 04:03 AM
hozie's Avatar
hozie
OK, that makes sense. I do like the ones that are mostly black in the middle with a silver/bar metal colored ring around the outer rim. That may not be too bad then.
Old Apr 26, 2007 | 04:24 AM
HighDuke1911
get a bigger tire too if you want that smaller rim look too.
