Tranny cooler
Old Apr 29, 2007 | 02:11 AM
Midnightrider's Avatar
Midnightrider
Default Tranny cooler
Right now I have 3:55 gears and im soon jumping to a 4:56, is the stock tranny cooler good enough to keep my tranny cool with the 4:56's or should I add and 2nd after market cooler? For you that have done this gear change and havent put a 2nd cooler in how is ur tranny holding up?
Old Apr 29, 2007 | 03:00 AM
Ben D.'s Avatar
Ben D.
Default RE: Tranny cooler
I don't think new gears would really put that much strain on the tranny. Maybe It would get slightly hotter just because your turning higher rpms but I don't think you'd need an aftermarket cooler. but if you can get one for a good price why not. better safe then sorry.
Old Apr 29, 2007 | 08:28 PM
Powerubi Wacon's Avatar
Powerubi Wacon
ORIGINAL: Midnightrider
I would think that the factory cooler is sufficient since my Ram came from the factory with 4.56 gears and no additional cooler. Still rated to tow 10,500 pounds with this set-up.
Old Apr 29, 2007 | 08:33 PM
deanj287's Avatar
deanj287
what is your truck? QC RC?? 4x4 or 2x4??
Old Apr 29, 2007 | 08:49 PM
kvsmith2004's Avatar
kvsmith2004
If it came with 4:56's it must be a power wagon
Old Apr 29, 2007 | 09:09 PM
deanj287's Avatar
deanj287
midnightrider you need to be very careful fi your drive shaft is aluminum. unless your a 4x4 it is. they have been known to fail under the added rotational force the 4.56 gears apply. the shaft reaches alot higher speeds then intended and things go boom. if your a 4x4 your drive shafts are steel and shorter due to transfer case.
Old Apr 29, 2007 | 11:09 PM
Midnightrider
ok, I got a 1500 2x4 BUT my driveshaft has rust on it, that would mean its not aluminum correct?
Old Apr 29, 2007 | 11:13 PM
Midnightrider
Also does the power wagon come with the same tranny/coolers a 1500 with 3:55's would?
Old Apr 29, 2007 | 11:55 PM
deanj287's Avatar
deanj287
do a magnet check. grab a magnet off your frig and see if it sticks
Old Apr 30, 2007 | 11:09 PM
Midnightrider
Yea its steel magnet stuck to it.. do u know if there is a tranny/cooler diffrence between the regular 1500 and the powerwagon?
