Security Lug Nut
Old May 2, 2007 | 08:01 AM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
Default RE: Security Lug Nut
ORIGINAL: moodie
I've only had the RAM for less than a month now and this was the first time undoing the lugs. They were on their tight. I'm 6ft200 Ibs and work out andI definitely had to put my back into it [:@]. Does anyone know the torque rating the lugs are to be tightened to?
This will never fail you, always tighten bolts 1/4 turn before they break. I have thought on hundreds of occasions the breaking point was a 1/4 turn less than Ithought it was. You're a big boy, like me, tighten your lugs tight for you.
Old May 2, 2007 | 11:22 AM
moodie's Avatar
moodie
I have to get myself a good torque wrench so I know for sure I'm not over or under tightenting. I had one rim that was difficult to remove after all lug nuts were off. What is recommended to put on the back of the rim so it's easier to take off next time.
Old May 3, 2007 | 01:37 AM
derwood's Avatar
derwood
That's when it's okay to use Anti-seize! I put a little where the wheel makes contact.
Old May 3, 2007 | 05:13 AM
DeWalt378G's Avatar
DeWalt378G
As far as getting your lug off, go with the socket for removing stripped nuts as mentioned earlier. Some of you guys are reporting cracked ones. Lose the OEMs (if that's what they are) and get a nice set of McGards. One thing I've learned with security lugs is to make sure it is the first one you remove and the last one you put on. Always tighten by hand. This makes the remove/install process easier later on. Also, a general rule is to never use an impact on them. Repeated use will eventually crack or strip the "keyed" part of the lug. Antisieze? I've never used it on lugs. I give the hub a squirt of WD40 every time I pull my wheels. It lubes the studs, keeps the hub pretty, keeps the wheel from sticking.
Old May 8, 2007 | 12:38 PM
moodie's Avatar
moodie
Finally replaced all keyed security lugs with normal ones. I had to take it to a tire shop to get the cracked lug off ... they also had a hard time. Tire guy said to torque them to 115 or 120. I feel better now that if I do get a flat in the middle of nowhere I will be able to change the tire without problems.
