need help removing deck!
Old May 2, 2007 | 11:06 PM
Eckel's Avatar
Eckel
Default RE: need help removing deck!
Some one please help me?
Old May 2, 2007 | 11:08 PM
HemiLonestar's Avatar
HemiLonestar
The piece on the outside slides up a little first, unlocking it, Then you can pull it the rest of the way.
Old May 2, 2007 | 11:14 PM
Eckel's Avatar
Eckel
I dont think we are talking about the same chord, its the one with the foam on it.....
Old May 2, 2007 | 11:20 PM
Eckel's Avatar
Eckel
Old May 2, 2007 | 11:23 PM
HemiLonestar
I just attached 2 pages from the service manual on my previous post, 2nd page shows the wire. You have to slide that black piece up, thats what locks it in!
Old May 2, 2007 | 11:58 PM
Eckel's Avatar
Eckel
I got it thanks everyone!
Old May 3, 2007 | 01:05 AM
benefactr's Avatar
benefactr
Just wondering, the service manual says remove the negative battery lead, is the 100% necessary or not necessary at all. I think it's done to prevent the airbag from deploying. Just wondering thanks.
Old May 3, 2007 | 01:32 AM
HemiLonestar
I didn't, it has nothing to do with the airbag.
Old May 3, 2007 | 03:59 AM
hemiyellow's Avatar
hemiyellow
DC Insider
ORIGINAL: benefactr
they put that in their to CTA (cover their ***) plus depending on what your doing you should anyways, but hell i never have cept when i did a clockspring recall on the minivans
Old May 3, 2007 | 01:23 PM
Horseapples's Avatar
Horseapples
As electrically dependant as new vehicles are,disconnecting the negitive battery cable prevents the possibility of stray voltage being accidentally introduced into a critical system. Lets say you are wireing your stereo,lots of open leads,the hot wire accidentally grounds. The voltage will take the path of least resistance, if the ground for your engine management computor is close,well, you get the picture,,,right?
