2004 Dodge Ram 4.7 Runing Hot
Old May 5, 2007 | 01:15 AM
79vette's Avatar
79vette
Default 2004 Dodge Ram 4.7 Runing Hot
I have a 2004 Dodge Ram 1500 with a 4.7 v8, I notice that it was runing hotter then normal, I took it to the dealer and had them check it out , they recommended to change the thermal stat and change coolant , I pick up the truck today and drove it home and it is still runing half way between half and the red, Help.
Gene
Old May 5, 2007 | 11:36 AM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
Default RE: 2004 Dodge Ram 4.7 Runing Hot
If it's just like it was when you dropped it off then take it back.
Old May 5, 2007 | 11:05 PM
tinyfxds's Avatar
tinyfxds
Don't pay for the service if they don't garantee the work. You could spend a lot of money letting them guess what's wrong.
Old May 5, 2007 | 11:22 PM
rob usa's Avatar
rob usa
your radiator is slighlty clogged
if they changed the thermostat and fluid that is the only other thing it could be
Old May 6, 2007 | 12:08 PM
CarGuyOhio's Avatar
CarGuyOhio
You said they recommended. So does that mean you did it or did they?
You may just have air in the system as well.
