20" wheels? better check your PSI!!!
Old Sep 14, 2004 | 11:01 AM
hemiwolf's Avatar
hemiwolf
Default 20" wheels? better check your PSI!!!
HI folks...
Just a quick heads up. It would seem that there is an issue with the 20" wheels from dodge holding air. I'm not sure if it is climate related or not.. but I read a post about it... went out and checked mine.. and got freaked out.. they were all very low... I mean REALLY LOW! only 12- 20 psi. So i did my own test and here are the results:
Making sure the tires were cold, I filled all four of them to 35 psi. I let the truck sit overnight and went out the next day and checked them. 2 wheels were down 4psi... one was down 8 psi.. and the last was down 12 psi.
The dumbest part about this is.. I can't tell the tires are low when I drive it. I don't know if it is because they are 20" or what. Maybe I just got used to it.
Anyway... check it out..
see if you have the same issue.
I'll take the truck to the dealer and see if they can find any punctures, leaky valves, or rim deformations. I just thought I would mention it.
drive safe!
Old Sep 14, 2004 | 12:47 PM
moparturd's Avatar
moparturd
Default RE: 20" wheels? better check your PSI!!!
hemiwolf. You should check the tire pressure every couple of weeks worst case, best at least once a week. Tire pressures are sensitive to temperature changes. I've found that for a 10 degree change in ambient temperature, say from 60-70, the pressure can vary as much as 3 PSI.
Old Sep 14, 2004 | 12:50 PM
texas dodge's Avatar
texas dodge
I try to check mine every time I fill up with gas....
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
I don't have 20's, but I never check my tires... makes me concerned... be safe everyone!!
~Amanda
Old Sep 14, 2004 | 01:11 PM
Reorg's Avatar
Reorg
Granted I only have about 1600 miles on my 04 QC Lonestar 4.7 with 20s, but I checked my tires and all are still 33 - 35 psi an that is in Texas where temps have been 91 - 94.
Reorg.
Old Sep 14, 2004 | 05:06 PM
RAM04's Avatar
RAM04
I have 20's. Live in Texas. Fill mine cold to 32 PSI. I check them once a month, cold, and all are within one pound of 32 PSI.
Old Sep 14, 2004 | 05:17 PM
hemiwolf's Avatar
hemiwolf
Got the truck back...
3 of the 4 valve stems were leaking....
AND
2 tires had very small punctures.
(Aren't I lucky!)
As much as I drive I guess it had to happen.
btw...
I do check my tire preasure every now and then.
they have always needed some amount of air....
Its been awhile I admit... it just got progressively worse i guess.
The truck probably had leaky valve stems from the
get go... anyway.. be safe..
fyi my truck has the 275x55x20 Good year EAGLE LS
Tires. in case "bad valve stems" might be a tire specific thing.
Old Sep 14, 2004 | 05:26 PM
moparturd's Avatar
moparturd
Man. Your having some crappy luck with this truck aren't you? I hope it gets better.
Old Sep 14, 2004 | 05:37 PM
adamsredlines's Avatar
adamsredlines
ORIGINAL: hemiwolf
Valve stems have nothing to do with the fact that you have Eagle LS's on your truck...apples and oranges, you just got "lucky" to have bad stems, lol. Glad it wasnt the rims, that could be an expensive problem to fix.
