Showing my ignorance
Old May 23, 2007 | 09:03 PM
norcal_fisherman's Avatar
norcal_fisherman
Default Showing my ignorance
As I said in my last post I'm new to owning a Dodge, and actually new to modifying any vehicle, but I can't help myself. I have read a lot of posts on the forum and have noticed a lot of people have a SuperChips Flashpaq. What is this? What are the pros and cons of having one on my truck.
I have an 06 Ram 1500 Quad Cab. Tomorrow a Flowmaster 50 Series Exhaust will be installed with twin pipes out the rear. Please inform an ignorant man wanting to have the best truck in town.
Old May 23, 2007 | 09:30 PM
Sir Hardin Thicke's Avatar
Sir Hardin Thicke
Default RE: Showing my ignorance
From my limited understanding of these performance chips, they are a good thing to have. Just wish one was available for my truck.[&o]
Old May 23, 2007 | 09:41 PM
HuntinHanson's Avatar
HuntinHanson
It has different settings for your truck, you can adjust it to be better for performance or towing, it can read engine codes, reset for different tire sizes, change shift points, pretty cool little device.
Old May 23, 2007 | 10:57 PM
Gone Fishin's Avatar
Gone Fishin
Super chips, and others are essentially a means by which you can modify the factory program that is installed in your computer that controls the engine dynamics---an application modifier if you will. By plugging the superchips programmer into the diagnostic port on your truck, it allows you to make minor mods, and it gives you choices of what performance mods they loaded into the programmer. As you may or may not be aware, the potential of the 5.7 is much higher than what it is actually being used for, and DC loaded a relatively conservative program into these.Generally, the apps that the programmers load will not allow you to destroy your truck, so long as you don't continually abuse it. With the new exhaust--you will no doubt notice a more than subtle difference in its performance, and believe it or not, better gas mileage. I don't personally have on mine at this point, but from all the talk and results posted here on the forum, it seems like a mod you won't regret.
Hope this helps!!
