How to adjust projection headlights?
Old May 24, 2007 | 07:16 AM
BighornHemi's Avatar
BighornHemi
Default How to adjust projection headlights?
Hi,
I just recently installed some projection headlights on my 2005 Dodge Ram. Could someone tell me how to adjust them? I can't find any adjustment screws. Please help, thanks.
Old May 24, 2007 | 01:49 PM
kenihemi's Avatar
kenihemi
Default RE: How to adjust projection headlights?
When I got mine, the brights were fine but the lows needed to be raised.
The brights have 3 silver bolts about an inch and a half log.
The lows have 2 screws on the back of the light itself. If I remember right, they are on the bottom. So if you pull the bottom on both sides in the light will go down and visa versa. A little more on one side will go right/left.
They are a pita to adjust. You have to remove them, make an adjustment, put them back in many times.
Old May 24, 2007 | 06:08 PM
BighornHemi
Hi,
Thanks for the help. Im going to check it out now.
