Header Help
Old May 24, 2007 | 09:30 PM
pakaalbite's Avatar
pakaalbite
Default RE: Header Help
they make different ty0e of locktite. Some are permanent and others are still removable
Old May 24, 2007 | 09:37 PM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
ORIGINAL: pakaalbite
Red Loctite: More permanent
Blue Loctite: Not
Old May 25, 2007 | 02:59 AM
DeWalt378G's Avatar
DeWalt378G
wow, everybody is gobbing on the locktite. i used antisieze!!!! steel bolt in an aluminum head, i think i want antisieze. i haven't had a problem yet. no leaks and it's been about 2 years.
PB Blaster rocks! btw
Old May 25, 2007 | 06:29 AM
ibanezta's Avatar
ibanezta
wide band setups are better because they read more than stock. a stock O2 sensor reads from 14-14.7:1 air/fuel ratio. your computer gets feed back from that and adjusts accordingly. a wide band will read from like 1-20 air/fuel ratio. this will allow you to tune in to the best combustion combo. some even come with data logging capabilities so you can kinda get it adjusted yourself. check out www.rpmoutlet.com they have a couple different ones on there. the new O2 sensor that it comes with will just go where yours is right now.
