Painted Handles Completed
Old May 30, 2007 | 12:24 AM
Denniss66's Avatar
Denniss66
Default RE: Painted Handles Completed
That looks really good i was thinkin of doing the door handles and mirrors on my truck but then i just covered them with chrome. i like your tail lights what kind are they and where did you get them from.
Old May 30, 2007 | 02:53 AM
HuntinHanson's Avatar
HuntinHanson
what kind of paint did you use? what did you do the prep the plastic you painted?
Old May 30, 2007 | 02:46 PM
chopperzen's Avatar
chopperzen
Cleaned with 91% Isopropyl Alcohol, sanded with 400 and then 600grit wet sand, then cleaned again with the alcohol. Let it dry, blew it off with the air hose and then sprayed 3 light coats of MarHyde Adhesion Promoter on it and let that dry for 20 mins. I use Nason base from DuPont. It's a little bit cheaper. Then sprayed 2 coats of Nason SelectClear 2K and wet sanded with 2000 grit and sprayed a 3rd final coat.
Old May 30, 2007 | 02:52 PM
zman2800's Avatar
zman2800
Was it hard to pull the handles apart to paint them? Or did you even have to do that?
BTW, Looks Great!
Old May 30, 2007 | 03:02 PM
chopperzen's Avatar
chopperzen
I pulled the handles off of the truck, but not the two components of the handle. Didn't want to mess with screwin up the spring or anything. Thanks! I think I am gonna pint the mirrors. That's the first thing my wife said I should do when I got the handles back on. I've heard it by half a dozen others since too.
Old May 30, 2007 | 03:31 PM
HuntinHanson
yeah they're right, those mirrors would look sweet with the handles painted too
Old May 30, 2007 | 03:44 PM
chopperzen's Avatar
chopperzen
Yeah. I just dread the part where i have to copy the screw holes onto abase to be able to paint them cuz I can't ley them down..
